2005 Acura TL Lost ability to arm factory security
Can anyone assist/offer guidance on “Anti-Theft” system fuse/relay #?
Suddenly CANNOT get system to “arm”, (nor does panic button sound from remote).
CAN lock/unlock doors inc'l trunk & front hood but NO BEEP; Fobs ARE recognized (both Driver 1 & 2
At "Unlock”, interior lights come ON; Exterior lights DO NOT (neither headlights nor “side” lights flash, as had previously);
Have “Reset” remotes (“Lock&Unlock” pressed simultaneously); Have pulled & reset under-hood fuses and relays.
Would like to self-diag & save some dealer labor if issue is a quirky thing or a "simple fix". Gracias...
have pulled all under-hood fuses & relays; thought that would accomplish a reset similar to what you're suggesting. I'm I wrong; will battery "kill/reset" accomplish something that hasn't been already? Appreciate the info..
Stay Out Of the Left Lane
The entire alarm circuit has to be closed for the system to be armed. First thing I would check is if the red led security light is flashing on the driver's door. It flashes approximately every 8 seconds IIRC. My guess is no, which would indicate the circuit is open.
Driver side door/Red led security light NO LONGER flashes, though LED on console (left of CD slot)DOES flash. All 4 passenger doors, trunk & hood close without restriction, firmly and seem tight. Getting no A/B codes nor other from MID which might indicate there is an open "entry". Nothing on MID that might indicate other electrical-type failure. Thoughts on next move? Many thanks in advance of replies
handsom-hustla
Nov 13, 2015 05:04 PM
nuldabz
Sep 3, 2015 05:49 PM
