2004 TL Timing Belt Problem
I just completed the timing belt change at 105k miles, Now I have three issues:
1) Engine MIL light in on and will not go off.
2) VSA light is on (both the VSA indicator ("VSA" on dash) and the VSA activation indicator ("!" on dash). Pressing the VSA switch on dash does nothing.
3) Car has no power and it will not rev above 2k rpm in first gear.
I checked the alignment during the job several times and rotated the crank about 10 times once the belt was on to ensure all the marks aligned properly. No issues.
Checked alignment marks on cams now (removed rubber covers) all looks good with white line on cam pully at proper mark on belt cover.
Need help....
Need help....
AZ Community Team
Received 7,770 Likes
OP is getting responses in this thread: https://acurazine.com/forums/3g-tl-problems-fixes-114/problems-after-timing-belt-change-04-tl-833949/
asahrts
09-04-2015 05:55 PM
