2004 TL light issues
Old Dec 9, 2019 | 09:39 PM
2Quik's Avatar
My daughters 04 TL front light was out so i ordered some lights. I change the bad one and after i turned on the lights and both lights worked. i turned the lights off and back on but the one i replaced didn't turn on not sure what happened but i check the igniter and it looked burnt, see pick. I check the fuses and all looked fine. Also the high beams don't work on that said also. Anyone have any clues as what it might be or could have caused the igniter to burn?
Old Dec 10, 2019 | 12:13 PM
2Quik's Avatar
Does the ballast control both high and low beam lights?
Old Dec 10, 2019 | 12:25 PM
there's only one bulb for low/high. when you click 'high' on the stalk, it drops drop a mechanical solenoid in the projector to go 'high'
That igniter looks bad.
Old Dec 10, 2019 | 01:22 PM
2Quik's Avatar
duh, not sure why i thought there were separate. ya it does look bad. I am going to replace it. Hopefully its not the ballast.
Fan4purdue
Aug 1, 2016 06:20 PM
CL-S progression 01
May 24, 2013 06:12 PM
RRSV
2G CL Problems & Fixes
Jun 12, 2010 12:25 AM
whtetls02
Apr 22, 2008 02:45 AM
autoxCLS
Nov 28, 2001 01:42 PM
