2004 Electrical System Shutdown
Old Mar 27, 2012 | 11:52 PM
sleddude's Avatar
Occasionally the entire electrical system shuts down and after a second and sometimes a minute turns back on. If this happens after the engine is running the system comes alive within a second or less. I have sometimes returned to the car and noticed the clock and stereo have reset. The stereo requires the "code" as if the battery has been removed. This issue occurs only during warmer weather in which the AC is needed. Any ideas? Does the system have and main power relay?
Old Mar 28, 2012 | 01:50 AM
RainSupreme's Avatar
Wtf?!? Loose/Corroded battery terminals?
Old Mar 28, 2012 | 05:56 AM
truonghthe's Avatar
^^^either that or bad battery my 2nd gen TL did that before but after I replace the battery the problem is gone.
Old Mar 28, 2012 | 10:20 AM
sleddude's Avatar
Battery is good. The Hands Free Link is not responding as of this morning after another power cycle reset. It now has happened frequently in the last week just as the ignition is turned off. I have read some interested posts about the HFL causing batteries to die due to HFL failures. Maybe the HFL failure and the power cycle are related. HMMMMMMM.
Old Mar 28, 2012 | 01:13 PM
Project_CLean's Avatar
MMkay.
check your ground strap off the battery..sounds like a short to me.
Old Mar 28, 2012 | 01:57 PM
pohljm's Avatar
How do you know battery is good? How old is it? These cars are very sensitive to battery issues.
SinCityTLX
20
Oct 19, 2015 11:23 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
joflewbyu2
Oct 8, 2015 11:16 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
2Quik
Sep 23, 2015 01:03 PM
