2004 acura tl transmission double shift from park to drive
Brought my car in to the dealer Friday..they say the transmission needs replacing...!!!
When i shift from Park to drive it feels like a double shift.
The Tech said it is not normal..
2004 Tl 107 000 kilometers ..i'm in Canada
Any help ?
Any help ?
try and get the transmission goodwilled. call acura client services. can you describe the double shift from park to drive in detail. I sorta experience that in that my car will have a slight thump and a 2 second delay before engaging from reverse to drive.
my symptom
Thanks for quick response..when i shift from park to drive ..or reverse to drive is starts to engage normally then after maybe 2 seconds gives another jerk to fully engage..it feels like a double shift (clunk) to me..instead of just one clunk to get into gear..what normal cars do..
Sounds like the same symptoms as your transmission...did you try to resolve the problem ?
Ahhh not so bad for you...did they replace the mounts?
Maybe it could be that also on my car...but the dealer i went to wants to replace the whole transmission for like 5000.00 ...I called Acura Canada and are only offering a 700.00 rebate..on a transmission that should not be broken in the first place...at 107 000 km not miles ,i'm in Canada
Let me know if your problem got resolved..
I will go get a second oppinion somwhere else..
Thanks again
nanos
11-12-2015 08:41 PM
Mike Bertram
09-10-2015 09:27 AM
