2004 Acura Tl Problem!!!!
Old Dec 22, 2007 | 03:40 PM
Joe Avesyan's Avatar
OK, I RECENTLY BOUGHT A 2004 ACURA TL WITH 65,000 MILES. SO, LIKE EVERY OTHER AVERAGE TEEN, I WANTED TO SEE WHAT MY NEW TOY COULD DO. I OPENED IT UP ALL THE WAY TILL REDLINE AND THE CHECK ENGINE LIGHT STARTED BLINKING. MY QUESTION IS, IS IT SUPPOSED TO DO THAT AND IF NOT WHAT MAY BE THE PROBLEM.
THANKS FOR ANY ANSWERS
Old Dec 22, 2007 | 04:14 PM
loojoohnnyl's Avatar
sound like u damage something take it to autozone or something and get them to check out ur check light
Old Dec 22, 2007 | 10:01 PM
I hate cars's Avatar
If you let it sit there on the revlimiter, it will probably throw a light. Otherwise there's a problem somewhere.
Old Dec 23, 2007 | 02:14 AM
01tl4tl's Avatar
chances are you got the cat hot during all this play and caused a temporary overheat condition- hopefully its temp. Catalytic convertor damage is a real issue, and overrevving the engine- bending a valve when it contacts the piston and many other things await kids and adults who fail to understand the vehile they are operating
Old Dec 23, 2007 | 07:33 AM
bhelsdon's Avatar
were you driving or sitting still? Go to some place that can read the codes for you, if you have a p0300, p0301,p0305(these are misfire codes) check out TSB 03-033. Read the TSB and see if the criteria matches. You can read the TSB on this site in the 3G garage.
Old Dec 23, 2007 | 10:55 AM
I was sitting at a red light and when it turned green, i eased on the pedal until redline. My car is automatic, no i was not sport shifting, and i only redlined until 2nd gear.
Old Dec 23, 2007 | 12:09 PM
bhelsdon's Avatar
http://www.in.honda.com/Rjanisis/pubs/SB/B03-033.PDF
Here is the TSB I was referring to. Get the codes read from Autozone and see if they Match the TSB. Just get the codes from Auto zone and don't listen to what they say you might need. They are NOT qualified to interpret the codes.
Old Dec 24, 2007 | 02:07 PM
Thanks for the tip. I really appreciate it.
Old Dec 24, 2007 | 07:23 PM
Tech7427's Avatar
Under your Acura...
when the check engine light blinks, its because a catalytic damaging misfire is occuring..
good job.
Old Dec 24, 2007 | 11:03 PM
Oh BTW, could this check engine light and/or a misfire be the cause of poor gas (Example 87 or 89)?
Old Dec 25, 2007 | 02:51 AM
Tech7427's Avatar
Under your Acura...
most definately, especially with the more aggressive high load timing maps that honda runs
Old Jun 30, 2014 | 04:47 PM
hunkyn's Avatar
Could someone please upload this TSB if they have it. My car is coming up with a TSA and engine light at the same time and when i did the research this TSB is supposed to fix it.
Thanks in advance
Old Jun 30, 2014 | 05:23 PM
nfnsquared's Avatar
Thanks in advance
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-technical-service-bulletins-tsbs-3g-garage-j-016-a-613659/
Find the TSB and follow the instructions in red at the top of the page before clicking on the TSB link.
Old Jul 1, 2014 | 04:30 PM
hunkyn's Avatar
https://acurazine.com/forums/showthread.php?t=613659
Got it Thanks
AndrewS
19
Mar 14, 2024 06:59 PM
Zonian22
Nov 14, 2015 01:20 PM
Mike Bertram
Sep 10, 2015 09:27 AM
Redsand353
Sep 6, 2015 01:03 PM
NSolace
Sep 3, 2015 08:02 PM
