2 problems
2 problems
First problem is my 05 TL when it's idling I can feel the engine jerk a little bit, its hard to explain it but the engine has a jump to it when idling. Second problem when applying the brake slightly I get a anti- lock feeling when I step on the brake slighlty
motor mounts, do exactly what the name implies. mounts the motor.
the engine does torque or move, wearing out these motor mounts.
a worn motor mount will make the engine torque or move more pronounced.
TIRES, are very important.
if you're losing traction, it will engage ABS.
I was thinking the idle issue you are referring to would more likely be the A/C compressor kicking in and out which causes the motor to drop RPMs and then quickly recover. Our 05 does this and it is definitely noticeable.
justnspace (07-12-2012)
SidhuSaaB
05-30-2020 12:40 AM
Fool
03-10-2016 08:42 PM
