12v power outlet/cigarette lighter not working
I have a 2005 TL with nav. Yesterday my phone's charger stopped working so first I thought it was the charger. After trying to other chargers I believe my outlet isn't working. I read online a fuse might be out. I called advance auto parts if I buy the fuse from them if they will replace it but they said no. What are my options? I don't want to go to a mechanic and spend hundreds on fixing up the lighter outlet of a 10 year old car.
Check the fuse yourself and replace it yourself. There's a fuse box inside the car located on the drivers side floor and one underneath the hood also on the drivers side.
If you can pump gas you can change a fuse.
Changing a fuse is just unplugging it and plugging a new one in, it's that easy. Just take a look at the diagram on the cover of the fuse box and it'll tell you which one needs replacing.
On another note, I have a Moto quick charger that's supposed to use the whole 12v. My power outlet in front of the shift knob doesn't seem to be charging it at a full 12v, but the charger itself works fine in my other vehicles.
The fuse box covers have fuse block diagrams.
The last few pages of the owner's manual also has the diagrams of the fuse boxes and fuse ratings.
There is a fuse puller in the fuse box under the driver's side dash-- use it to pull out the suspect fuse. Look at it to see if the fuse is blown, and replace the fuse with a fuse of the same rating if it is.
IIRC, there are also several spare fuses of different ratings in that fuse box too.
Take a look at page 258 and the list of "Circuits Protected" in the diagram chart.
mada51589
Jan 9, 2025 04:40 PM
