08 type s not getting to op temp?
Old Jul 16, 2023 | 06:28 PM
Mcgo101's Avatar
Hey guys got another 3rd Gen, this one is a very clean 2008 type s with 169 original kms on it with no clutch fade or rust anywhere. Question is about coolant temp. It only gets up to 5 ticks off the cold line, halfway between cold and middle? Even after an hour cruise that's as high as the temp gauge got. My 07 tl s would get upto almost halfway. Parked it for 30 mins and checked under the hood, engine felt hot still thru the engine cover. Coolant topped up, overflow at full line, oil at full line no signs of issues that I can see.
is this a sign of a thermostat stuck open? Or do they make colder range thermostats? Any help is greatly appreciated!
Old Jul 16, 2023 | 08:47 PM
The_head's Avatar
Mine gets about 5 lines above cold as well. I think that's normal.
Old Jul 17, 2023 | 10:03 AM
Mcgo101's Avatar
On board diagnostics show she's at 95 deg Celsius when fully warmed up, and that's at 5 ticks above the cold mark. Both rad fans are working as well.
just wanted confirm this is OK for it or should I put a new oem thermostat in it just to be sure. Thanks folks!
Old Jul 17, 2023 | 11:57 AM
peter6's Avatar
OEM thermostat should be fully open at ~90C. Temp in my TL stays around 1/3 of the range as well. I would say it's all right.
Old Jul 17, 2023 | 12:32 PM
twokexlv6coupe's Avatar
Normal.
Old Jul 22, 2023 | 12:43 AM
Sacto Civic's Avatar
My 08 is the same as yours, but my ‘05 runs pretty much in the middle of the gauge.
I *think* it’s more a difference in the display range of the gauges than a difference in operating temps, but I’m not positive. Either way, both of my cars temps never budge once warmed up.
peewizzle
Jan 3, 2020 10:44 PM
computerwizard56
2G TSX Problems & Fixes
20
May 31, 2015 04:22 PM
Luqman
Aug 28, 2013 04:12 PM
punky
Feb 25, 2012 02:37 PM
NSXNEXT
Jan 7, 2004 09:41 AM
