'08 Type S clutch problem
Ok I'm sick of searching my tl-s needs a clutch what's the best street set up I can do I just got the car so it's mostly stock not sure if I'm gona mod this one yet or not. Also I'm having the problem with the clutch getting stiff when I go through the gears and by 3rd sometimes 4th the clutch does not disengage I removed the check valve but still doing it thanks for any info
going through what you have, I believe the pressure plate is worn.
After I changed out my clutch, the stiff pedal after a high rpm run was gone.
Change out the clutch.
if you're not going to mod it, stay OEM.
The OEM clutch set is made by LUK.
Member Hi Speed is turbocharged and he ran a stock clutch all the way up to 350whp.
Ok thanks I do my own work and always resurface the flywheel when installing a new clutch unless I'm missing something on this car and there's a reason you can't. I have a few cars but there Esther b series or k series so I'm new to the j series. I'd hate to sell this car already but I don't want a car I can't easily work on myself
justnspace (07-07-2011)
Huh I wonder why not? cause once they get a little wear you think it would effect the new clutch kinda like brake pads you never just change the pads I always turn/cut the rotors or get new ones if I cut the once before. But I do all that stuff myself also so I don't know if a dealer does that they prob. Replace both so I'm sure they say replace flywheel clutch and plate all at once
1fatcrxnem1
22
06-01-2018 01:23 AM
sockr1
10-01-2015 01:31 AM
Billu99tl
09-13-2015 11:30 AM
brandnewcolony
09-12-2015 10:39 AM
