08 Type-S 6MT. Initial Acceleration bucking issue
Old 12-03-2017 | 11:28 PM
alexpapas90's Avatar
I have a 2008 Acura TL Type-S 6 Speed.
I have another post regarding swapping to a 3.7 MI and TB. Not sure if that would help the problem below.
The issue:
When i give my car gas it bucks slightly a bit from 1st to 2nd and 2nd to 3rd for some reason, only when I give it gas initially... then its fine. I've already replaced the APP sensor (NEW) and that didn't do anything. I also swapped out my throttle body with a used one to see if it would help... it didn't. Even replaced the Map Sensor AND ALL MOTOR MOUNTS. Additionally, I had the dealer re-flash the ECU. I'm shifting at like 3K - 3.5K RPMs each time.
I was thinking the 3.7 IM and TB would help with throttle response and eliminate that initial acceleration bucking.... perhaps im wrong.
Old 12-04-2017 | 12:07 AM
Duronn's Avatar
Was your car doing the bucking prior to the swap?
Old 12-04-2017 | 12:09 AM
I haven't done the swap yet. But, ever since I've owned the car its done this. Really annoys me.
Old 12-04-2017 | 12:33 AM
Duronn's Avatar
Does it still buck when you WOT it from first 1st-2nd, and from 2nd-3rd?
