08 tl starting problems
Old Mar 28, 2019 | 02:46 PM
JBlount2001's Avatar
5th Gear
Hello I've recently baught a 2008 TL not running,got the car a couple of weeks ago with the timing cover off,the timing had jumped what looked to be about 3 or 4 teeth,so I baught a new belt and reset the timing,turns over with good compression, its getting fueal in the cylinders and spark when I ground any of the plugs out,only code was for the temperature sensor, any thought or idea would be much appreciated
Old Mar 28, 2019 | 03:19 PM
horseshoez's Avatar
Latent car nut
You need to either replace the cylinder heads or have your heads reconditioned/rebuilt.
Old Mar 28, 2019 | 06:58 PM
5th Gear
Oddly,the heads look like they've been recently replaced, they look new and they had definitely had the intake manifold off,old intake gaskets were in the car. So you think it may have bent some valves since the timing was off?
Old Mar 28, 2019 | 10:42 PM
horseshoez's Avatar
Latent car nut
If the engine was rotated even as much as 60° of a single turn since the timing belt jumped teeth, you have bent valves.
earthbound741
Apr 3, 2008 08:56 AM
NYCAcura2.5TL
1G TL Problems & Fixes
Jul 28, 2007 09:57 AM
bimmer88
Technology
48
Apr 21, 2006 10:41 PM
robdog82
Oct 14, 2005 04:33 PM
RaptorCLS
May 15, 2003 07:51 PM
