08 acura TL (shifting issues)
Old Apr 25, 2020 | 10:36 PM
Noneed2brag's Avatar
Hey guys, i have an auto, 08 Acura TL with 174k mls. Just purchased it today for 2500. It was a desperate buy do to my other car dying on me. I have an ill wife and child and need transportation for doctor visits. Anyway, i notice the car hesitates to get in 3rd or 4th gear and it down shifts kinda rough. Was hoping someone would have any insight on what the issue may be? First and second work just fine so far and fifth but as i said, when i slow down and it down shifts, its kinda rough like its stuck in the gear then goes.
Old Apr 26, 2020 | 09:10 AM
Ron A's Avatar
Administrator
Welcome to the forums.
The following is posted at the top of the New Member Introductions forum: Welcome! Please introduce yourselves here, BUT ASK FOR HELP IN THE TECHNICAL FORUMS
Since this is a topic/technical issue which will require replies and discussion, and not an introduction, this thread has been moved to the model specific forum.
Old Apr 26, 2020 | 10:56 AM
vpasla1's Avatar
I would start with changing the transmission fluid. I would follow that with reseting the ECU.
My guess is your due for a fluid change with that mileage, and that the previous owner's driving habits are stored in memory.
Old Apr 26, 2020 | 10:31 PM
I didnt know it could do that. I need to do my research. Ill keep an update.
Old May 1, 2020 | 03:22 PM
YJLTG-TLS's Avatar
Definitely would do the 3rd (two of them on the 07/08) and the fourth gear pressure switches for the transmission if it was mine, they seem more preventative but this sounds like textbook failure of them. They are a bit pricey but have the piece of mind of getting oem ones, if you replace them right after you add (or in the middle) of the atf change and reset the ecu (several videos online) it will probably help it significantly but definitely do it as soon as absolutely possible.
Transmission problems of slipping/hanging are a call for help from it and if ignored they die, just like people...
deetreyy
Sep 23, 2019 08:56 AM
Melinda Baker
Sep 14, 2019 07:38 PM
Whiskeyjack
Jul 10, 2018 08:57 PM
astro
AcuraZine Articles
26
Sep 3, 2017 06:16 PM
KushTL
Jul 31, 2017 07:11 AM
