'07 TL Type S Idle Engine Vibration
Old May 19, 2016 | 08:33 AM
ritchie2428's Avatar
7th Gear
Just today, when I started my car up for the second time after driving it for maybe 10 minutes the check engine light came on.
I noticed that it only turns on when the car is idling, but when I'm accelerating it goes away.
When the car idles, there is definitely a noticeable vibration in the cabin and the engine itself after I opened the hood.
Any suggestions?
Old May 19, 2016 | 08:58 AM
read the code
Old May 19, 2016 | 09:01 AM
the check engine light is a key or a clue to finding out your issues.
we cant automatically scan your car from the interwebz(although that would be a cool app)
Old May 19, 2016 | 09:03 AM
I'm working on it Cap'n!
Old May 19, 2016 | 09:05 AM
*robot voice*
"scanning, scanning, scanning, scanning, scanning....
problem detected....
would you like me to fix that for you?"
7th Gear
So I don't have an OBD Scanner. Guess I gotta go buy one
Old May 19, 2016 | 09:06 AM
head to your local automotive store!
its free to check, unless you live in cali.
autozone always helps me out with my codes!
be sure to write down the EXACT code
Old May 19, 2016 | 09:10 AM
Jackass's Avatar
Get the codes pulled and go from there. Sounds like a miss at idle which can be caused by all kinds of things from plugs, coils, EGR, bad gas, valves, phase of the moon, solar flares, etc..
Old May 19, 2016 | 09:19 AM
7th Gear
I'll check the latest astroweather to see if there was a solar flare today. Must've missed it this morning.
Old May 19, 2016 | 09:29 AM
With the way this week has been going on AZ, I'm pretty sure there was some solar flare or Mars and Jupiter were having a fit again..
Might be something Idle Air Control valve related or TB dirty as well
Old May 20, 2016 | 09:30 PM
csmeance's Avatar
Any suggestions?
with a type-s the navi should be able to spit out the DTC code without a scanner...
Old May 21, 2016 | 08:41 AM
7th Gear
I think it does, but the navi should have alerted me in the first place. However I went to my mechanic friend and he read the code for me and said there were misfires from old spark plugs. I don't know the age of the spark plugs, but if they were original ones it's about time because my car has 130,000 miles on it.
Flipster23
Norcal
262
May 4, 2023 02:47 PM
EE4Life
Dec 20, 2022 05:16 PM
EE4Life
Mar 12, 2020 07:29 PM
EE4Life
May 14, 2016 07:14 AM
GK83
Sep 13, 2014 12:48 AM
