'07 TL Type S clutch problems
Old Jul 29, 2015 | 08:55 PM
junior_TLS's Avatar
Hey guys my TL has been giving clutch issues no gears go in i have to force them in and float my gears to drive. Replacing clutch tomorrow but im wondering if its a different type of issue then replacing the clutch i remember my honda civic's burned clutch going in gears but just not grabbing them.
Old Jul 31, 2015 | 07:41 PM
DMZ's Avatar
DMZ
Head a da Family
Did you replace the flywheel too? What I've learned is when you replace the clutch, REPLACE THE FLYWHEEL! I replaced my original clutch at 180K miles, the new clutch went at after another 40K. Makers of our clutch, LUK say to replace the flywheel at the same time since a worn flywheel has the propensity to take the clutch with it due to the characteristics of that dual mass flywheels represent. Any wear in the flywheel is guaranteed to damage the clutch.
Old Jul 31, 2015 | 10:03 PM
01acls's Avatar
Clutch problems not engaging is usually a leaking clutch master or slave cylinder or worn clutch master cylinder. However, it could all so be a defective pressure plate problem, unable to disengage.
If the clutch is not slipping then it's probably not a clutch problem. It's more of a release problem.
Check the clutch fluid level to see if it's low or leaking. You may even try bleeding it first to see if it makes a difference. If it does then it's definitely a hydraulic problem.
If the clutch pedal is low then it could simply be out of adjustment or a sign that it's a hydraulic problem.
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
sockr1
Oct 1, 2015 01:31 AM
Billu99tl
Sep 13, 2015 11:30 AM
brandnewcolony
Sep 12, 2015 10:39 AM
heyitsvic
Sep 4, 2015 09:38 AM
