'07 TL Type S AVS and check engine light turned on
car has about 92k well maintained and today the AVS and check engine light turned on i lost power in low gear and the check engine systems appeared and well as throughout the course of the day.....the gear shifter was also stuck in park for a short time as well....
p0627
U0107
P0705
vehicle stability 61&71
i was reading up on the the APP sensor and was wondering if that could be causing these other issues.....im going to have a diagnstic check monday but was hoping for insight before then
thanks
p0627
U0107
P0705
thanks
Welcome to the forum. ![Cheers](https://acurazine.com/forums/images/smilies/cheers.gif)
The forum where you originally posted, The AcuraZine User Help, Support & Suggestions Area , is meant for problems, comments, and suggestions for the website itself, so I moved your thread to the car specific forum applicable to your vehicle.
Coolest A-zine Member
Diagnostic?...like at the shop or you have another code?
I'm getting P0718 and P0717 right now and it's showing it's a "Mainshaft/Input Shaft Speed Sensor". I'm also in the same boat and have no clue whether this is a simple fix, where the sensor is located and if that's the fix or if it's something deeper.
so an update..........i changed the starter because i had it checked and it was dead.....my battery is only 3 months old the starter is new. i replaced the starter and now the car just turns over and attempts to start but wont. i called a locoal acura and he said i should look into the starter ignition under the engine???????? the avs warning came on the nav screen and caused the car to stall also.................
mada51589
05-03-2022 08:54 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
