'07 TL simple AC problem
Old Feb 16, 2015 | 08:52 PM
Gocardinals's Avatar
Just drove through an ice storm to Florida from St. Louis with the heat blasting, now went to put the AC on and it is not blowing. Would this be a fan motor or compressor any ideas? Pretty sure I heard some weird noises at some at some point during the trip. In addition I just noticed the lights on the passenger temperature up and down buttons just went out. Any ideas? Thanks
Old Feb 17, 2015 | 02:54 PM
csmeance's Avatar
There is a way to perform HVAC diagnostics by holding a series of buttons down or by flashing the lights.
How to do it:
Originally Posted by Turbonut
As there are many components involved, driver's and passenger's mode control motor, driver's and passenger's air mix control motor, plus other sensors and transistors, might want to try a self diagnostic test to see if any DTC appear.
Turn ignition on
Press and hold the OFF button. While holding the OFF button, press the circulation button 5 times within 10 seconds. Release the OFF button and the self-diagnostic will begin.
If there are any problems in the system, the temperature indicator will light up the segment of (A through S) corresponding to the error. The temperature indicator will then alternate every second between displaying "88" (all segments lit) and error code (A through S). To determine the meaning of the code you'll need to the DTC troubleshooting index.
If there is no problem detected, the segments will not illuminate.
Turn off the ignition switch to cancel the test.
Each part of the "88" indicates, or translates to a specific letter, e.g. top of the first 8 on the driver's side is a C, top of second is a D, passenger side temp, top of first 8 is a L, etc. and each segment indicates a specific problem.
Don't have a scanner so can't load the detection code values, but just as an example, if the top of the first 8 is lit, that would translate to a C:
C-An open in the outside air temperature sensor circuit.
At least you can see if there are any codes to indicate a problem within the system.
Code definitions:
https://acurazine.com/forums/problem...eaning-860536/
SidhuSaaB
May 30, 2020 12:40 AM
LoneRonin
Jan 4, 2016 01:03 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
