'07 TL-S squeeky belt noise issue
so i was driving my 07 tls and stopped at a light and heard my car squeeking really bad. i took it to the dealer today and luckly they heard the noise too ( i tought with my luck it would stop when i got there) and the tech said it was something aroung the timing belt or something.. and they would need to order some kit or something? and i could replace my timing belt early ( i only have 31,000 on my car) for only the cost of the belt...has anyone heard of this or had this problem??
Are you sure they said timing belt and not drive (AKA serpentine) belt?
I highly doubt it's the timing belt. The serpentine belt and/or the auto-tensioner for that belt have been known to be noisy. Many times just flexing the auto-tensioner and/or repositioning the drive belt takes care of the problem.
Try to find out exactly what they are talking about. They might be talking about the timing belt tensioner, but I kind of doubt it at that low of mileage...
i will, its covered under warranty so im not paying a dime. ive heard of this once before a really long time ago but i cant find anything on it now. and its driving me crazy
just an fyi i dropped it off today and they said that basically they are changing a tensioner to an updated one. and so im getting my timing belt changed at the same time for like 65 $.
Why are they charging you $65 if it's under warranty? For the belt itself?? If so, they're ripping you off. List price for a TB is only $55.68...
Hi can you please confirm that this has resolved the problem?
They replaced the "timing belt tensioner".
07 TL-S, I'm going to the dealer for the third time next week.
Cold startup sounds like a squealing belt/accessory or tensioner bearing.
Although it's all warranty covered, if I can save future trips that would be appreciated
AZ Community Team
Received 7,771 Likes
I think there are a couple of issues with squeaks in this area. Check the TSB's on this page: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-technical-service-bulletins-tsbs-3g-garage-j-016-a-613659/
Be sure to read the instructions to access the PDF's at the top of the first post.
Maybe TSB 08-031? Or TSB 10-035?
Dealer fixed the issue. I believe there may be a TSB for this.
They had to replace the bolts on the AC compressor. The stock bolts are too short and wear, eventually loosening the pulley. The wobbling pulley is what creates the squealing.
New bolts are longer, have not had the problem since I got it fixed a couple months ago.
snorf
11-04-2019 06:44 AM
