'07 TL Power Mirror and Memory Seat Issues
Old Feb 7, 2014 | 07:50 PM
Comptechtl2367's Avatar
Hey everyone, let me start out with saying I have search this already and the fix for the 05 TL is not the same as a 07-08 so please do not link it to this thread.
Now the issue:
Ever since it started getting cold I have noticed when I unlock and start my car one or both of my rear view mirrors will automatically adjust all the way up or down and pop until I hit the switch to stop them. Also I now notice that my memory seat function no longer works. The two things may be unrelated but I think they are connected. Also my seat will not adjust when I unlock with my remote or my fiancés.
The fuses are good, obviously because they are still getting power. There is not a 7.5 fuse in the number 20 spot under the dash as I stated above. Any help would be awesome!
Thank you!
Old Feb 7, 2014 | 08:18 PM
ZOMGVTEK's Avatar
I have the same problem.
I replaced the MSC under the driver seat that supposedly controls this stuff, and it didn't do anything, so its probably not that.
I never use the memory seats, or auto mirror tilt, so I never pursued it past that.
Old Feb 8, 2014 | 03:29 PM
My fiancé and I switch off driving it and she is 6-7" shorter then me so it's a huge pain in the ass!
Anyone else have some input?!
Old Feb 8, 2014 | 03:33 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
bad mirror actuators?
the mirrors and seat memory work off the same "circuit" if one of them goes bad it acts up.
OR the key fobs are not syncing to the car correctly.
Old Feb 8, 2014 | 06:06 PM
That was my thought too but the mirrors only do it maybe 1 in 10 times. The seat memory does not work when you push the button inside too.
Does anyone know what fuse runs the memory seats?
Old Feb 8, 2014 | 06:15 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
i've been told by my dealer after my MDX went through 3 mirror motors already (1 driver's side and 2 passenger side)....that even if they start (read: occasional to intermittent) to act up the whole system gets goofy. and the button in the car doesn't work as well.
sadly even after 10 yrs of this annoying issue in Acura's....they still occur in the newer models. i had a loaner RLX....mirror actuator was starting to act up (7 month old car and about 9k miles on it). i told the dealer about it so they could fix it.
not sure on the fuse for the memory seats...who has a service manual?? chime in.
Old Feb 10, 2014 | 12:59 PM
Update:
I disconnected the battery overnight on Saturday and the memory seats worked great all Sunday. My Fiance went to take the car to work this morning and the memory seats are not working again.
The mirror issue is gone and they work without a problem.
I know this is not a huge issue but I am not the type to let even little issues with my vehicles slide. Does anyone know of any fixes for this like the ones for the 04-06 model?
Old Feb 10, 2014 | 06:16 PM
ZOMGVTEK's Avatar
I ran into a few people claiming the mirror actuators can 'go bad' and cause the memory seats to have issues. It makes little sense the systems would be that connected, but its certainly possible.
I might throw new mirror actuators at it, since any feature not working bothers me. Even if I never use it. I never disconnected the battery. The car has been sitting a few months, maybe it fixed itself.
Old Feb 10, 2014 | 06:45 PM
Jase13's Avatar
They are. When you unlock the vehicle it adjusts the mirrors and seats to the driver's specification(1 or 2).
Old Feb 10, 2014 | 06:59 PM
ZOMGVTEK's Avatar
Yeah, but it sounds silly they would be in 'series' effectively. If one of the mirror actuators has an issue the seat memory breaks too? I guess they counted on nothing breaking.
Old Feb 10, 2014 | 07:44 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
^^the mirror actuators go bad, break the circuit. it doesn't mean the memory seats are broken.
dealers kind of figured this stuff out the hard way. in the MDX the steering wheel is power telescoping which is linked to the memory seats and the mirrors. they tried "fix" the steering column/rack thinking that was the faulty part, but ultimately they found out the mirror actuator was the culprit.
comptech-i still say fix the mirror actuators. just b/c it's intermittent doesn't mean that all is well. it's up to you...
Old Feb 10, 2014 | 08:35 PM
ZOMGVTEK's Avatar
It depends what you consider broken. My seat memory buttons do nothing when pressed or held. They don't beep, the seats don't move. If I move the seat manually, it never ever moves with key 1 or 2. I'd consider that broken. Conveniently, my mirrors also don't recall position. If I put the car into reverse with a mirror selected, it goes down for as long as the car is in reverse and does not go back to the same spot.
One would think it's possible to have the memory mirrors just not work, and the remainder of the memory functions work as intended if a failure occurs. Not have the whole system fail if any piece has an issue.
Old Feb 10, 2014 | 09:16 PM
rubenders's Avatar
performace tl-s
Yes they all work togather on the mirro there is a lateral and vertical sensor that let the memo seats know how far up,down or in the mirro are if one of this sensor go bad the intire memo system Wong work.
Old Feb 10, 2014 | 09:21 PM
rubenders's Avatar
performace tl-s
This is the replacement Part # 76210-STX-H03 I replaced my 1 year ago no more problem.
Old Feb 10, 2014 | 10:31 PM
bp_spets's Avatar
I had the same issue with my car when I got it a week ago, it was below freezing last week and my mirrors were acting up just like yours, moving all the way up and getting "stuck". The memory seats were not working.
I unplugged and replugged the battery and cycled the mirrors to all four corners multiple times. I also sprayed in a bit of WD40 to help lube up the mechanism in the mirror housing. That seems to have fixed the issue for now, although I plan on pulling the mirror glass off when its warmer out to relube the actuator. When it's this cold out I'm afraid of cracking the plastic.
I suggest moving the mirrors around and trying to lubricate the actuator / mirror base.
Old Feb 10, 2014 | 10:58 PM
ZOMGVTEK's Avatar
I already pulled them apart and put some grease in there. Apparently these things are sensitive, and that surely didn't fix it.
I'll just get some new ones eventually. Probably at some point when it warms up, right now the car is stuck behind several feet of a snow/ice mountain.
Old Feb 11, 2014 | 02:45 PM
Thank you everyone for the help!
The mirror actuator assm are cheap! I can get them locally at cost. Now here is a dumb question, I will need two correct? One for each side?
Also how do you pull the mirrors apart? I am nervous to just pull on the glass and break one.
Old Feb 11, 2014 | 04:22 PM
Slpr04UA6's Avatar
-------Tim-------
^this might help some.
https://acurazine.com/forums/3g-tl-problems-fixes-114/3g-mirror-repair-pictures-3g-garage-e-045-a-832020/
Old Feb 12, 2014 | 08:19 AM
Perfect, thank you!
I just got a call from my fiance that she went out to go to work today and the Acura is now dead. The battery was put in less then a month ago so I know that is not the issue... I am hoping it could be related to this mirror issue.
I am really starting to question the quality of Acura products... I have had this car for less then a year and have had way more issues then my 04 G35 coupe had in two. I am hoping its just due to the cold but it is getting old real quick. I see selling this car and going back to Infinity in my future! (End Rant)
Old Feb 12, 2014 | 08:33 AM
photog's Avatar
Originally Posted by Comptechtl2367
Perfect, thank you!
The quality of all the ancillary components has definitely gone downhill. I've owned my '07 for less than 2 years and here are a list of component issues I've had:
-Upper Trans Mount and all 3 motor mounts torn @ 60k
-Motor Oil Pump Leak @ 70k
-Purge Control Solenoid failure @ 75k
-Starter failure @ 85k : did a partial rebuild
-Torn control arm bushings (all 6) @ 90k
-Starter failed again @ 95k and I did a full rebuild
-PS Pump leak from the main body @ 100k, rebuilt with all new seals. still makes noise.
-Driver-side Axle cracked in the winter @100k, replaced
-Positive end of battery cable broke apart near the starter from a weak cable-end. Replaced.
-Coil failure at 105k
-Taillight leak at 105k
-Valve Cover spark plug tube leak at 115k, causing a loose spark plug that I was unaware of for about 10k miles
Old Feb 15, 2014 | 09:48 PM
racerock's Avatar
Perfect, thank you!
Similar things are happening with mine.
I recently hit the unlock button to open a rear door and did not go in and start the car. Turns out the mirror was trying to find the stored position until the battery ran down...
I think I will be trying the mirror fix above because the issues here are identical to what ours is doing.
Old Feb 17, 2014 | 09:11 AM
Update:
I replaced both mirror motors and the issue is fixed! Not only do the mirrors move a lot smoother, the memory seats not store like they should. Also the mirrors now tilt like they should for a curb view.
On a side note, i broke both motors pulling the glass off. So if your planning on trying to just lube them you might as well just replace them. They are cheap (35.00)!
Old Feb 17, 2014 | 09:54 AM
TLtrigirl's Avatar
3G TL/2G MDX Owner
Glad everything worked out. I may have to finally fix the ones on my TL. Upside is that I am the only driver so the memory seating and mirrors aren't really that big of an issue and I don't' use the reverse tilt function.
Old Feb 18, 2014 | 07:46 AM
Yeah, if I was the only driver I think I still would have fixed it because the mirrors kept doing whatever they wanted. That and I cant stand when there is a single issue with my cars.
Old Feb 18, 2014 | 08:22 AM
bp_spets's Avatar
Just tried to do it myself to take the mirror off to lube up the actuator per that DIY, and what do you know, cracked the glass. that sucker was on there tight.
Might as well do both of them, so $40 per mirror and per actuator.... sigh.
Old Feb 19, 2014 | 11:16 AM
I didnt crack my glass but I did break both motors when I tried pulling the glass off. For 35-40 per motor, you might as well just replace them instead of lube them.
Old Feb 20, 2014 | 12:49 AM
TBone728's Avatar
Mirrors/Seats issue
I just recently discovered the same problem in my '05 TL. I already have a bad actuator in the passenger side mirror that I need to replace. Now, the driver's mirror is acting crazy where I can only adjust right and down. I discovered the memory seating isn't working as well. I just received a Chiltons manual in the mail yesterday so I'll be doing some homework today and let the 3GTL world know what I discover that's worthwhile...
Old Feb 20, 2014 | 04:39 PM
There is really nothing to research... the motors need to be replaced to fix the issue.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
PortlandRL
Sep 14, 2015 12:01 PM
