07 TL 3.2 shake/jerk after warm
Just recently started having an issue where, once the vehicle is warmed up and has been driven for awhile, at a stop light the car will shake or shimmy suddenly every few seconds. This doesn't happen right away, I'd say after about 20-30 minutes of drive time.
I've watched the RPM's as it happens and the needle doesn't move. I've also pulled into a parking lot after this happens and it does the same in park. It doesn't seem to drive differently or shift abnormally while driving, just at idle.
I've looked at other similar posts, but nothing has been described exactly as I'm experiencing. Any ideas on what I should check?
Looking closer at the tach, it seems that it runs normally when the needle is right on the 7. It will then jerk and the needle will slightly move just below the 7 and then gradually go right back to it.
