'06 TL interior settings suddenly changed and radio code comes up
Old Nov 15, 2012 | 10:16 AM
Midnightbui's Avatar
8th Gear
Wassup guys, wondering if you can help me figure this out. My TL is suddenly acting weird. It first started with the remote didnt even work and i had to use my key to get into my car. But then the remote worked when i got home. This morning it worked but this time when i got into my car, my clock was way off and my radio needed the code. Not sure if any other settings were off.
Can anyone explain what it can be. Remote batterry? Car Battery? I actually changed my car battery a year ago so that should be good. Never changed the remote battery though but i have read that some Acura models would have an alert to change the battery. I could be wrong but that is what i read.
Thanks in advance.
Old Nov 15, 2012 | 11:42 AM
Ron A's Avatar
Administrator
Welcome to the forum.
The forum where you originally posted is meant for problems, comments, and suggestions for the website itself, so I moved your thread to the car specific forum applicable to your vehicle.
Old Nov 15, 2012 | 12:19 PM
nfnsquared's Avatar
check for loose/corroded battery cable connections, especially the positive cable connection. also check fuse #7.
Old Nov 15, 2012 | 01:21 PM
8th Gear
ok thanks. Can you send me the link to that forum, i am unable to find it where you moved it.
Old Nov 15, 2012 | 01:51 PM
Jackass's Avatar
3rd Gen Problems & Fixes - https://acurazine.com/forums/forumdisplay.php?f=114
My guess is the battery clamp is loose or broken.
Old Nov 15, 2012 | 02:32 PM
8th Gear
Does anyone think it is the battery on the remote?
Old Nov 15, 2012 | 03:07 PM
pohljm's Avatar
nope
Old Nov 15, 2012 | 07:49 PM
Jackass's Avatar
Battery on remote could explain the remote not working. It would not explain any of the other oddities you described.
Old Nov 21, 2012 | 04:27 PM
8th Gear
Ok im getting frustrated now, ive tried everything from resetting the remote to disconnecting and cleaning the battery. Its weird, my remote 2 works fine and when used the inside panel says driver 2 detected or something like that, but my remote, remote 1, does not come up at all. All my settings are removed but the annoying part of that is i cant program all the doors to open with one push of the remote and at night i like my inside lights to be at max but everytime i turn on headlights i have to press max.
Does anyone else have ideas of what it can do. One last thing i havent done yet is change the battery in the remote. i will do that today or so. but i highly doubt that it is that.
Old Nov 22, 2012 | 12:37 PM
Jackass's Avatar
Sounds like remote 1 is not setup properly. Read the manual on how to sync the remote so it will apply the driver profile. Are you wanting both remotes to behave the same? I know on mine I use remote 2 while the wife uses remote 1 and each of his have completely different settings.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
handsom-hustla
Nov 13, 2015 05:04 PM
braveheart
Sep 7, 2015 08:12 AM
iRaw
ILX
Sep 5, 2015 12:10 AM
