06 TL Aspec pulls to the left
Please help!!! Bought brand new off showroom floor 06 TL with Aspec. After 5000 miles took into dealer to have oil changed and rotate tires and mentioned that car pulled to the right. They did a wheel alignment and said everything was fine. Still pulled to the right. Took it back again and they said it was the tires. Car came with Yokohama tires but dealer recommended putting on Michelin tires at my expense. I said no and they replaced all 4 tires with new Yokohama tires. Did another wheel alignment and said it was good to go. Still pulled to the right and now steering wheel shaked back and forth. Took it back again and they still said it was the tires and now Acura will cover cost difference and put on 4 new Michelin tires. Now the car pulls to the left when you drive in the left lane and the lane is crowned to the left. If you are in the right or middle lane with the road crowned to the right, the car stays straight and will eventually drift to the right. But if in the left lane and the road is crowned to the left it really pulls you towards the gaurd rails. Anyone else have this issue???
is your steering wheel straight when the car pulls or is it canted towards the left, cuz mine is.... my sterring wheel looks like im turning left when the car is going straight and when i holdthe wheel straight the car turns right any ideas
Too Fast TOO FURIOUS
^^^ sounds like alignment problem.
my steering wheel was "turning" right by itself when I led go of steering wheel. pretty hard right. I tested it on different surfaces and conditions. making sure it's not the road. it pulled right no matter what. so, that prompted me to have it checked out.
My 2005 had the same problem pulling to the right. If you let go of the wheel on any road, car immediately went right. It was no gradual move. On a long trip, my side actually hurt after holding the wheel straight for 500 miles.
The car has basically done it since new. Took it in and they said it was out of alignment and they gave me a free alignment. Got it back and it still pulled to the right. Took it back. They said it was in alignment so now they said they needed to replace two front tires. I have the Michelins. This fixed the problem for a little while. After putting about 2K miles on the tires, it began pulling to the right again. Took in again for A1 service and mentioned the pulling again. After they rotated the tires they said it wasn't pulling. I checked and now it doesn't seem to pull. It's probably a matter of time before it starts pulling again.
Acura Owner
SidhuSaaB
05-30-2020 12:40 AM
