'06 TL 6MT 3rd gear gets stuck
Old 08-25-2007 | 01:26 PM
tstranz's Avatar
7th Gear
Hello... Anyone experiece this problem?
When I try to shift from 2nd to 3rd the gear will not go in all the way.
I either have to push it really hard or put it back into 2nd and 3rd again.
Any ideas? I went to the dealer and they said that they could not reproduce the problem.
Thanks in advance
Old 08-25-2007 | 01:40 PM
Pizza4Everyone's Avatar
i have the same problem. 3rd gear nightmare man. try to put it on third and sometimes doesn't go in all the way. it happens when engine's cold.......so you might need to warm it up abit.
Old 08-25-2007 | 05:03 PM
Yakuza70's Avatar
This is a very common problem and discussed very frequently here in the forums. Do a search and you'll find many discussions and solutions.
The quick and most effective fix would be to change your transmission fluid to GM Synchromesh Friction Modified transmission fluid.
Old 08-26-2007 | 03:18 PM
Adobeman's Avatar
The DVD-A Script Guy
Not another 3rd gear thread.
What he said. Nobody I know of, including me, has regretted using the GM Synchromesh Friction Modified transmission fluid.
Mods, please
Old 08-26-2007 | 05:25 PM
BG74's Avatar
Yup...that's the fix. My '05 and '07 6MT's both had the 3rd gear problem, remedied immediately by the GM fluid.
Old 08-26-2007 | 08:09 PM
hollandca12's Avatar
Mods, please
Ditto! Just changing the tranny fluid made a world of difference. Do It!
Old 08-26-2007 | 10:51 PM
DMZ's Avatar
DMZ
Head a da Family
Old 08-27-2007 | 10:01 PM
Tumbler's Avatar
7th Gear
Is there any break-in mileage one should reach in an '07 TLS 6sp before changing fluids? I have the same 3rd gear problem with 2400 miles on it.
Old 08-28-2007 | 06:42 AM
tstranz's Avatar
7th Gear
Thanks for the answers. I talked to my dealer and they told me that they will not change the fluid for me, but they will look at it again. I will post an update on Friday.
Old 08-29-2007 | 09:04 PM
Dwarflord's Avatar
I changed mine about 6kmiles ago to the synchromesh. It took about 500 miles for all the 3rd gear "notchiness" to go away, but it does and until I just read this post, I had forgotten about having the problem entirely. Huge difference, change the 6MT fluid.
Old 08-31-2007 | 07:16 AM
tstranz's Avatar
7th Gear
UPDATE !!!
Picked up my car from the dealer and they said that they changed by tranny fluid with their version of the "MESH" under warranty
So far so good.
Old 08-31-2007 | 04:15 PM
Adobeman's Avatar
Originally Posted by tstranz
UPDATE !!!
So far so good.
If your experience with the newer Acura MTF is like mine your happiness will be short lived and you'll be back to pondering the GM SMFM fluid. I hope not but I bet so. Sorry.
Old 08-31-2007 | 07:28 PM
Yakuza70's Avatar
UPDATE !!!
So far so good.
My dealer changed out my original fluid with the newer "Mesh" fluid too to try to remedy the third gear problem. It was silky smooth with no problems for about a month before the issue came back in its full glory.
Old 08-31-2007 | 07:57 PM
Polixtroy1002's Avatar
had this same problem, went to the dealer and over a year later and its buttery smooth.
Old 09-01-2007 | 05:20 PM
Adobeman's Avatar
Sounds like they slipped you some GM stuff.... Anyway, as long as it's shifting right for you that's what matters.
Old 09-02-2007 | 09:30 AM
trancemission's Avatar
Regions Leader
Gm is the fix, end of story. I went in for many tranny fluid changes at acura.
Problem never went away until I put the GM fluid in....
Please search before you post your next thread...
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
Quick Reply: '06 TL 6MT 3rd gear gets stuck
