05 TL Problems Starting Any Suggestions?
Old May 29, 2017 | 08:46 PM
  #41
Originally Posted by Erb757
the battery was relatively new, when i had that battery up at the place charging!!! I took my little brothers 05 Ex Accord's battery still the same thing with all of the new parts installed. so i doubt it's the batter right now!!! I've realized when i reach under the passenger seat it's been wet. for some odd reason! i remember myself driving threw a DEEP ass pool of water which i couldn't tell it was that DEEP and this was weeks ago it's still kind of damp. i have no roof leaks etc! could it be possible for water to get in from beneath any how?
Dude..This is a HUGE piece of information that you just so happened to let slide?? Thst plus the green key blinking sounds like your immobilizer (potentially paired with your ECU) is on the fritz... Me thinks you'll need an ECU after all
Old May 29, 2017 | 09:00 PM
  #42
Erb757's Avatar
yeah i did put the video up at first on my newer post, idk if it was still loading on YT or not but that immobilizer situation was hard to call also with no code! so i kept putting both keys in and just watched to see if it would ever cut out, or even blink a few times! not trying to kill the battery or hurt the car anymore.. should I buy a used ECU if that's the problem? or just go ahead and spend the arm and leg with the dealer to have them fix it? i know they have to program it if I did buy the ECU off of eBay or amazon which would be ALOT cheaper. Thanks man you guys have been a lot of help! i was losing my mind throwing these parts into it
Old May 29, 2017 | 09:47 PM
  #43
Chad05TL's Avatar
If you have the dealer work on the immobilizer, they will likely want to see the title or registration and your Identification. haha
Old May 29, 2017 | 09:57 PM
  #44
Erb757's Avatar
i have all of that in hand, well in the glove box lol so that wouldn't be a problem! what will save my pockets haha because, I know for a fact when i had my 95 LS400 I spent too much money at that damn Lexus dealer! a dust ring cover cost me almost 400+ including labor fees. I ended up cutting that damn thing out a yr later what a waste of cash. would you recommend DIY?
Old May 29, 2017 | 10:00 PM
  #45
Chad05TL's Avatar
My 05 does not have an immobilizer that I am aware of. And I know nothing about those at this time. I would either read up on it, or take it to the dealer before I would replace anything else.
Old May 29, 2017 | 10:29 PM
  #46
Erb757's Avatar
yours doesn't have a immobilizer??? lol you gotta be joking right... do you even know what that is yo?
Old May 29, 2017 | 10:55 PM
  #47
Chad05TL's Avatar
Yes I know what a immobilzer is. I have the Helm book and I read it for things that need to be fixed. But I would be more concerned with yourself wasting money on things that is not fixing your car.. And you're prepared to "dump your next paycheck" when that green key light is flashing in your face..
Old May 30, 2017 | 01:12 AM
  #48
Erb757's Avatar
you're right. I need to stop dumping money in the wrong places! I'm gonna go ahead and have it towed in, i just really enjoy the car haven't even took it on no real trips yet! it's alot going on with the electrical thing on these newer vehicles. I just don't want to mess it up to the point of no return.. I appreciate your help! much love brotha
Old Jun 3, 2017 | 09:53 AM
  #49
HoofheartedTL's Avatar
Keep us updated, curious to what you find out.
Old Jun 4, 2017 | 06:52 AM
  #50
DMZ's Avatar
DMZ
Head a da Family
OP, have you checked the condition of the + battery cable? At this age it might be corroded to the point where it's conductivity could easily be compromised. Mine had to be replaced last year.
Just a thought.............
Old Jul 14, 2017 | 12:01 AM
  #51
Erb757's Avatar
I finally found out what was wrong, it took a min.. since i was going threw a move out of town! The timing belt snapped, which caused it to die out the way it did. I didn't have them check for bent valves just yet.. the mechanic said more then likely i will have to buy a brand new/used head. which is pricey at this moment for me, I'm wondering any suggestions should i just go ahead and scrap the car? I'm looking at my insurance to see if it will cover it if possible. Or would you go ahead with a new head job? I really like this car but things have to happen thanks for all the support and help i can't stress how much, i really appreciate it!
Old Jul 14, 2017 | 11:29 AM
  #52
Jackass's Avatar
Very curious if the TB was ever replaced or is this the original TB?
As for scrapping the car? Only you can make that decision. Determine what the car is worth as-is, what it is worth repaired, and compare the difference with the cost to repair.
Old Jul 14, 2017 | 11:42 AM
  #53
Erb757's Avatar
It was never replaced! it's the original TB. from the looks of the shreds of the belt, it looked very aged and worn.
Old Jul 14, 2017 | 12:38 PM
  #54
horseshoez's Avatar
Latent car nut
My $0.02...
The cost of replacing the head or heads which were damaged will most likely be a fraction of what you would need to spend to buy another car anywhere near as nice. Scrapping an otherwise good condition car because of engine issues will only present an opportunity for the entity which buys the car.
Old Dec 26, 2017 | 02:22 PM
  #55
Erb757's Avatar
I finally got my baby back! Bent 6 intake valves 7 exhaust. The car runs good so far 375 miles in, I have a question my front driver side locks up!!! While driving, the ABS *!!* light, comes on but everything else is great any feedback on what this could be? Im getting no codes at all. It drives very well other then this problem! No Limp Mode Either
Old Dec 26, 2017 | 02:35 PM
  #56
Old Jan 3, 2018 | 11:01 AM
  #57
DMZ's Avatar
DMZ
Head a da Family
Ahh one of those crappy auto parts terminals.. I'd suggest replacing the entire harness https://www.oemacuraparts.com/oem-pa...9tYXRpYw%3D%3D
What he says..........
Old Feb 7, 2018 | 05:06 PM
  #58
Erb757's Avatar
Has anybody ever had a failing ABS wheel sensor, My car is running awesome.. but at times i get the vsa light + "!" then the driver wheel skids, any suggestions if this is indeed the ABS WSensor.
