05 TL No lights no power just dead
Old Mar 1, 2023 | 05:04 PM
Gaspar74's Avatar
9th Gear
Hello folks. Been a while since I’ve had to post anything however the other day after a quick trip to store went to leave and the car wouldn’t start. It acted normal a millisecond after inserting key then as crank it over just died. There is zero power to anything. Called AAA he checked battery and battery is fine. Suggested possibly main fuse 120/70amp large one. . I ordered it even though it looked fine and continuity was good. Well it and came today and nope didn’t solve the problem. The car shows zero signs of life. Checked the battery terminals and they were tight and looked fine. I checked fuses under the hood and all fine. Only one I didn’t check yet was a big 50amp as well as ones under the drivers side in car. I’ve seen a few threads but all pointed to the main fuse which I checked. Any help greatly appreciated. I know the 05 is old now but still love the car and no rush for a new one.
thanks in advance.
Old Mar 1, 2023 | 05:14 PM
do you have a multimeter?
Old Mar 1, 2023 | 05:44 PM
csmeance's Avatar
You need to use a multi-meter and check where the power is going and where it stops. Fuseboxes are a great place to start. Make sure power is making it to the starter also.
Old Mar 1, 2023 | 06:36 PM
Gaspar74's Avatar
9th Gear
HI, Yes I do. Where should I begin?
Old Mar 2, 2023 | 03:58 AM
El_Cheapo's Avatar
Check all powers and grounds.
Old Mar 2, 2023 | 07:21 AM
Pair of TLs's Avatar
A common problem is the battery cables--try wiggling them around with your lights on and see if you get anything.
FireFly
Apr 28, 2019 08:28 AM
ribasaurus
Jan 2, 2018 03:13 PM
Robmar26
Nov 23, 2013 03:13 AM
tjk8585
Oct 28, 2013 02:42 PM
GuddsCLtypeS
2G CL Problems & Fixes
May 16, 2006 10:18 AM
