'05 TL misfire at idle
im having issues with cyl #1 misfire at idle only. So far i've swapped coil packs cyl to cyl, installed new coil packs, replaced injectors (this got rid of the other 2 & 3 misfire codes), adjusted valves, swapped spark plugs, egr seems to be clean had the intake apart no blockages, checked for vacuum leaks. compression test is the only thing i have left. any other ideas?
Also spark plug wire/lead could be an issue. Sometimes it's the simple things.
DerrickW
Nov 15, 2015 05:52 PM
