05 TL M/T From Auction Electrical issues after Mods
Old Aug 13, 2021 | 10:31 AM
BKarcher's Avatar
Hey All,
I purchased this TL from Auction and discovered it has been tinkered with quite a lot. I am getting the following trouble codes and there is a lot of electrical wire splicing that has been done. If I reset the codes the car will operate OK and rev over 3500 RPM but after a couple higher RPM gear changes the car will no longer rev over 3500 RPM.
P0135 and P0155 for o2 sensors - These codes show up immediately after clearing codes.
P0498 - Evap Emissions System Vent Valve control circuit low
P2648 - A Rocker Arm Actuator Control Circuit Low Bank 1
P2552 - Throttle/Fuel Inhibit Circuit
I replaced the VVT solenoid and oil pressure switch and the Intake Manifold Runner control actuator to clear some of the other codes I was getting.
I took it to my local trusted shop for a deeper diagnostic and they suggested that due to the amount of tinkering with the fuse box and wire splicing that I should start by replacing the ECM/PCM, Fuse Box under the hood, and the Engine wiring harness. I was thinking of starting with the ECM but am worried that the existing electrical state may fry any replacement ECM.
I am in the Dallas area and looking for an 05 TL M/T that I can get these parts as a set.
Any other guidance would be greatly appreciated as well.
BK
Old Aug 13, 2021 | 12:43 PM
BK
The only car-part.com 2005 six speed I could find near you is in New Mexico. They have the ECM, engine fuse box and engine wiring harness listed.
Foreign and Domestic Parts - Albuquerque, NM - Five J's Auto Parts (fivejsauto.com)
If possible, you best 'jump' on it before the frankenstein peeps snatch up these parts.
Good Luck!
Old Aug 13, 2021 | 06:22 PM
csmeance's Avatar
there's a few grounds that could be loose, there is one by the throttle body that causes rocker arm A error if I remember correctly.
Old Aug 16, 2021 | 05:20 PM
BKarcher's Avatar
Looking for parts and will check the grounds.
Thanks!
BK
marteb73
Apr 23, 2013 07:20 AM
MoogLe
1G TSX Problems & Fixes
Oct 16, 2012 06:27 PM
civicdrivr
Jul 18, 2010 03:17 PM
EricL
Jul 25, 2002 02:12 AM
EricL
2G CL Frequently Asked Questions
Jul 24, 2002 03:51 PM
