04 TL Passenger side door not un/locking via power methods
I have an 04 TL and noticed a problem with my passenger door recently.
When I use my key fob to unlock/lock my doors, my passenger side door does neither though my other doors lock/unlock. If I try hitting the power lock/unlock button on the passenger side door itself, it also does not work yet all the other doors work. The only way to lock/unlock is to manually pull the door switch up or push it down. I'm not quite sure what is wrong with it.
Any help? I read somewhere it may be an actuator or something in the door but I'm not sure.
Thanks!
Thanks!
Actuator replacement
This job isn't too hard, just take care to not break the clips. The window chanel must be removed to access the actuator, and remember to re-attach both clips on the inner door release cable, or the door will not open from the inside afterwards.
marcelft
07-10-2018 06:17 PM
mike from annapolis
05-07-2017 08:21 PM
sockr1
10-01-2015 01:31 AM
