'04 TL: First Major Mechanical Issue
Old 05-22-2012 | 09:58 AM
obiedi's Avatar
The car developed a shake in the drive train while accelerating at highway speeds. This is a 6MT with 86K miles. The fix was to replace the left driveshaft. Ouch. Did not expect that.
I am wondering whether it was caused by having so much torque going to the front wheels through the LSD?
Old 05-22-2012 | 09:59 AM
Did it fix the shaking?
Old 05-22-2012 | 10:00 AM
Aman's Avatar
Your Friendly Canadian
Just for perspective, my 160 horse AT Accord had an axle that was going as well. So I don't think it's power.
Old 05-22-2012 | 10:02 AM
obiedi's Avatar
Yes it did. Now it is fine. I have no idea how it happened.
Old 05-22-2012 | 10:04 AM
obiedi's Avatar
How many miles did you have on it when it went? The AT models don't have an LSD to my knowledge.
Old 05-22-2012 | 02:22 PM
gwiffer's Avatar
I assume it was the inboard CV joint that failed, since they usually manifest as vibrations under load. Was the boot torn/ripped and losing grease?
I read a statistic once that claimed the average driver makes significantly more right-hand turns than left-hand turns. The driver-side (left) axle is under more load when the car turns right.
I would think that LSD might actually increase axle life by equalizing the torque between both axles.
Old 05-22-2012 | 04:54 PM
EATSLEEPRACE's Avatar
6SPEED FEVER
Replace axles...go oem if you can..it's worth it
Old 05-22-2012 | 10:29 PM
obiedi's Avatar
No, neither boots were damaged or leaking. If they were I am sure the problem would have been identified faster. It took a bit to diagnose since there was no obvious damage and the car drove fine below freeway speeds. The tech said that the left axle appeared to be slightly bent once it was pulled out. The right driveshaft had excessive play on the inboard side too so we just replaced both sides. I am the only driver of the car, so it is very odd that it just failed. Never had a problem like this before. My previous car was a '94 GSR that I drove about 150K in 10 years without any work besides the obvious maintenance items.
Old 05-23-2012 | 12:06 PM
Noel Persaud's Avatar
Thats true its not always too much power that causes these issues. Do you drive around any rough roads?
Ol'Dave
09-05-2020 02:56 PM
cycdaniel
12-17-2019 10:58 AM
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
Billu99tl
09-13-2015 11:30 AM
ninersfgiantsfan
09-09-2015 01:14 PM
Quick Reply: '04 TL: First Major Mechanical Issue
