'04 TL drifts at higher speeds
My '04 TL (177k miles) seems to drift on the highway and / or at higher speeds. It's not pulling in one certain direction, but rather gets away from me a little if I look down at the radio etc. and drifts in either direction. I've had the alignment done and tie rods replaced, motor mounts replaced, and it still does it. I could probably use 4 new tires fairly soon, and I also know that my rear struts are pretty shot. Could that be the culprit? Thanks.
As for what the cause is, hard to say, could be one or more bad tires, one or more bad control arms or suspension bushings, I rather doubt it is the rear struts.
don't think struts are leaking....thanks...still looking into this more
Could be tires, depending on how fast you are taking those corners...
I remember taking corners in both my 07's (base and type-s) at stock height, and I would be very aggressive in the corner and a couple times it would get away from me as well.
However, after having been lowered on teins, I take corners without any "slippage" now, I'm also running semi-new, beefier tires (DWS06)
I don't think @skierz means he's drifting in the sense of a rear tire slide. I think he just means drifting like you intend to go straight but you start to move into another lane, left or right lane in their case.
Recently completed work on car includes:
- New control arms and bushings on both sides
- new motor mounts - front and left side
- new front and rear brakes and rotors
- new front sway bar link
- new right front outer tie rod
- new serpentine belt
Current issues on the car include:
- needs a new O2 sensor - CEL code P2197 (O2 A/F sensor) and B251 signal stuck lean(?). Not sure if the "lean" part is correct due to mechanics chickenscratch writing.
- power steering high pressure line is leaking (already replaced by Acura via the recall so this one is out of pocket. Yes I called them and put up a stink but they weren't having it)
- car smells like gas in the cabin of the car - much stronger when it rains.
- car could use new tires
- CEL comes on intermittently
- could use new rear struts
Appreciate any / all feedback. Wow in looking at that list of new parts I should list in on Craigslist with the list and see what I can get. hahaha....
