04 TL clutch replacement
Old Mar 14, 2018 | 06:45 AM
Don Maw's Avatar
What is the special tool for self adjusting pressure plate? Look difficult to R&R for DIY Need video if anyone has replaced a clutch . Too scared to try it
will a regular Honda clutch work instead of original
Old Mar 14, 2018 | 07:33 AM
horseshoez's Avatar
Latent car nut
A few comments:
  • A regular Honda clutch is in fact a LuK clutch which includes a self adjusting pressure plate.
  • I just bought the SAC tool kit off of Amazon for $129.99.
  • There are videos on YouTube on how to adjust the pressure plate, it looks pretty easy.
  • I'll be doing mine in the next week or so.
  • I'm also taking this opportunity to swap out the slave cylinder for one from which I've removed the delay valve.
Old Mar 14, 2018 | 08:12 AM
horseshoez's Avatar
Latent car nut
One additional comment; I am considering coming up with some sort of a model where I can rent out my SAC tool to Acurazine members. I have no idea whether anybody would be interested, but just putting it out there.
Old Mar 14, 2018 | 11:02 AM
6spd-GERCO's Avatar
Check this link out. https://acurazine.com/forums/3g-tl-p...inside-860524/
Get a factory service manually if you don't have one already, I was able to replace my clutch no problem using that. Unless you are replacing your Dual Mass Flywheel, rigid clutch disc and self adjusting pressure plate with a single mass flywheel, sprung clutch dis and non - self adjusting pressure plate you will need to stick to the OEM parts, not a regular Honda clutch or sprung clutch disc. With the self adjusting pressure plate you have no packaging space for a sprung clutch disc.
Don't forget to replace your flywheel bolts, and rear main seal while you are in there.
Old Mar 14, 2018 | 11:06 AM
6spd-GERCO's Avatar
To your point on here, I have posted in the performance section but it seems to get glazed over.
The Clutch master cylinder also has a "delay valve" in it, the triangle shaped diaphragm on the end of the CMC is a delay valve. It's a common replacement item on TSX and RSX since they use the same CMC.
KimR710
Dec 20, 2017 03:21 PM
chrisedwards
1G TSX Problems & Fixes
Aug 29, 2013 10:20 AM
types1967
Feb 28, 2003 04:17 PM
