04 Acura TL
04 Acura TL
I have a 2004 acura tl automatic that I believe the torque converter went bad because after the car warms up it instantly doesn't want to move in gear, Oil smells very burnt and black even after a flush. While cold the car does move but jerks but as soon as the car is warmed up it slips out of gear and is practically in neutral, I found a good deal from a 2006 Acura TL automatic and I was wondering if the transmission would fit in the 04, Do they bolt up perfectly? Thanks
[QUOTE=Emir;16698825]I have a 2004 acura tl automatic that I believe the torque converter went bad because after the car warms up it instantly doesn't want to move in gear, Oil smells very burnt and black even after a flush. While cold the car does move but jerks but as soon as the car is warmed up it slips out of gear and is practically in neutral, I found a good deal from a 2006 Acura TL automatic and I was wondering if the transmission would fit in the 04, Do they bolt up perfectly? Thanks
Do you guys think it's a torque converter issue as well with the problem I stated above?
Long story short, for the best and most reliable automatic transmission for your 2004 is the BAYA coded AV6 transmission.
