'04 to '08 front lower control arm bushing failure - please read and look
lol heeltoe ur right its def nothing compared to the 2g issues with those trannies.... I just dont want the suspension slowly deteriorating or even breaking down in such a short amount of time... mine break down faster like 6months because i drive in the city. I brought this up to my mechanic at acura and he gave me a look like dude i can do this with my eyes closed, thats how many times hes replaced the arms on this car. y does honda have the part get replaced when its a simple press out, press in situation...they know the piece is junk and couldve n shouldve made it better by now n said something about it so people can get it replaced for a price.
I look at it as, if its not broken dont fix it but if theres an advancement...make it. lol
I'm trying to remember, you tried the type s and it broke too, right?
Please keep us posted, this may explain the mysterious side to side shimmy i've experienced. It's been a lot more noticeable since I lowered the car. I had the driver side half shaft replaced, had alignments and balance, had the motor mounts checked. Nobody can tell me what it is. I've lowered a few cars prior to this one and this is the ONLY one that does this. It's only really felt at low rpm/speed and kind of disappears when I get up to normal cruising speed. Almost like a "vibration" point.
I haven't looked at those bushings up close but, here are some urethane parts of a symmetrical shape:
http://www.goturethane.com/RunScript...p=ASP\Pg45.asp
http://www.polyprod.com/wheels.html
Ok, I dont know if I got the pic of the right thing, but it looks like I have the same problem too. I have an 06 with 49,7XX miles and am trying to get everything done before warranty runs out..
Left side.
Right side
Left side.
Right side
The are not failing on purpose man, lol. Honda knows how to make bushings just fine! A few ones go bad, yeah there is room for improvement. In the grand scheme of things I don't think this is a serious issue. Haha, maybe it is a possible new Fastline product tho!
I know people at Energy Suspension...hmmmm
^pnoi521,
join the 'race the warranty' crew! 48,500-ish on my 06. my dealer's service department slipped up and pretty much told me why they won't warranty mine; it seams that my dealership stopped stamping new bushings in a while back. They just replace the whole control arm, so it's a $$$ thing.
^pnoi521,
Ok...so what does everyone think is the permanent solution here? Do you guys think my symptom described might be fixed with this?
Here are mine
Passenger side
driver side
To me the passenger side looks busted!
Here are mine
Passenger side
driver side
I had a type s in here today that was just starting to go on teh driver side...there must be something we can do here. But making a poly bushing is going to make it pretty firm. It might be better to do a spherical bearing. But that can get pretty expensive.
Thanks for taking the time to check it out...I took a few more pics of the passenger side so I'll resize and post them. It has grease around it, like a CV boot rip or somehing, which is what made me think it probably is busted.
Besides, I can install it for free doing it myself.
this is what the poly would look like after one time going up down and it wont return to its form...this is my innovative mount before sending it out to replace. This is the reason i wouldnt go with poly for these applications.
and rock..the rip/tear occcurs on the top of the bushings...u took the pics of the wrong location. pnoi has the cracks if u take a close look, cant see them on yours clearly...on the passenger side it looks like a tiny tear occured. cant really see it though.
Meaning I took the picture from too horizontally, it's still the correct bushing I'm taking a picture of, right?! Want to make sure I got this right.
So just take a pic of the same thing from above?
I've been running poly in my driver's side engine mount and every suspension bushing is poly on the GN and I've never seen anything like that. I'm sure there aer different grades of poly, maybe these are cheap.
hmmm...I had taken multiple pics when I did...this one was probably the "highest" one. Looks damaged to me. Do they have a grease inside of them that would come out if busted? Reason I ask is cause the passenger side one was dirty and driver side was pretty much clean.
Thank you. And yes, I had the recall done so it probably dripped down onto it.
What about the symptom I described. Something I've never felt on any of my lowered cars. Some would say get a camber kit, but I don't have uneven wear and I dont' think it's camber related. I had the driver side half axle changed and it might not have even been the problem (that was at the recommendation of the acura shop foreman). It seemed to have gotten better but maybe it was only because I dropped 200 bucks on it...so it got better in my head.
This sounds like it could be a viable problem and the solution to my shimmy.
This was what I wrote above
"Anyway, I'm wondering if this is why I feel that shimmy when accelerating. I didn't own the car long enough before lowering it to remember if it happened once lowered, but that's when I noticed it. I had the driver side axle replaced already and it's still there. Not too bad, but kind of annoying. I did get used to it though. If mine are torn, that would make sense as to why they shimmy because that would give it the horizontal "play" it needs to make the car wiggle. "
It's like a slight vibration at low rpms and speed...once speed pics up it goes away and drives perfect well. Motor mounts are ok too...had that checked. It's a faint vibration that feels like the car is wiggling slightly and then disappears as speed pics up. Probably from about 1500 rpms to 2500 or so.
Those are the innovative mounts broooo. that happened because the top bolt of the rear motor mount came loose and broke all the mounts, probably over a period of 2 days or so. I didnt use loctite. Then i finally had time to put the car up n look... 3 or 4 days later.
I brought it home, stood the motor up on the oem jack . took it all apart n sent it back to replace. those are 60A btw.
Now my reasoning behind saying no to poly is because if the stock rubber ones are failing the way that they are (because of odd ups n downs and flexing back n forth) the poly would be waaaay too stiff and the ride would be ruined with poly and flex and stay the way that mine stayed..... if i can find a good complement between good tear factor, strength and vibration absorbtion in the mixes i ordered and the ride quality is still there (to a degree, because its going to be stiffer).... id make them and if people liked em...make more.
another pic.
and thats the side one...only one of the bushings flexed n froze in position.
now everything is fine...innovative doesnt ask questions .. 15$ for shipping n ur good to go.. and I used loctite this time =)
I'll be checking mine later...
I still think poly is worth a try b/c these two parts are under completely different weight loads and heat environments...
The engine mounts are arguably the most stressed components that are not internal.
I'll be checking mine later...I still think poly is worth a try b/c these two parts are under completely different weight loads and heat environments...
yea but the stress your putting on the suspension is constant once on the ground and the constant ups n downs n side to side motions are worse than the rocking of the engine n tranny in one place. plus with poly mounts the engine isnt even rocking anymore. you have to have the part return to an original state...once the poly flexes it stays warped....but again it depends on the type used. also poly is a much more rigid material than rubber.
i want to keep it as close to stock as possible without making the change noticable when looked at by anyone....ESPECIALLY the dealer. if rubber doesnt work... ill try poly...i have 2part poly but its too hard i need to find something a lil below 60a with a high resistance to tearing under load.
I'm not enough of an expert to know what the bushings reaching failure does to the suspension but, what I think we all agree it ain't kosher.
and the response from my dealer is unnacceptable: "They're just stress cracks. It's happened on all the Acura's I've owned. It doesn't effect handling."! WTF, Over?
I'm not saying my handling issues are directly related to my cracked mounts but I've had no luck tracing via all other suspension tests (alignment x2, balance x2, and new struts/springs)
I'm going in tomorrow to have the last of my warranty work done, and they said they'll look at my bushings, hopefully I'll get a better response than what everyone else has been getting
Please keep us posted. If this fixes the issue, I'll be a happy man. That little shimmy is the only quam I have with this car. Other than that, I feel like it's perfection.
