Smashed a tail light - Time to Modify!!!
A couple of weeks ago I noticed a piece of the underbody (skid plate or something) hanging loose under the rear end of my TL. Decided to take a look and fix it so I backed into my Garage which is higher than my driveway so that I could get under it easily. Didn't see the handle from my snowblower and backed right into it! Cracked one of my tail lights. I was pissed off at myself - for about a minute - and then decided it was a great excuse to upgrade to 07/08 tails! Wife would have no say in the matter.
Personally, I think the WDP looks way better with the 07/08 base tails. They go with the color perfectly. So I ordered a set off of eBay for around $130 plus shipping. Spent around 3 hours last weekend installing. Thanks to all the previous threads on this topic that I found on this forum, the install was easy and relatively painless - even with A-spec lip.
Here are some before, during and after photos. It's hard to see the crack in the 1st 2 shots, but then I broke it a little more (just for the records). Please excuse the bird crap on the bumper and quality of the photos.
Looks great!!
The last 3 pictures look like the LEDs are white.
Hot unitl they light up PINK
I take it you cleaned behind the lights before you took the pictures
makes the all red look look outdated
Thanks for all the positive comments!https://acurazine.com/forums/images/icons/icon10.gif
Shouldn't take that long if you know what you're doing. I had some problems getting the bumper clips off and broke a few. Also reaching the bolts in the tire well was a little difficult - easier once I jacked up the car. I wasted a good 1/2 hour trying to find a screwdriver that would fit the narrow gap. Ended up using a small ratchet with a screwdriver bit. Removing and installing the lights is very easy and quick but changing over the LED's is a little finicky because you have to thread the wires through a small hole and you have to try and keep the gasket in position. Good luck - it's worth the effort
Can you use the same bulb harness that the 05 uses for the 07 tails?
Does this upgrade require any cutting/joining of wires from the car?
Are there any pics showing the LEDs being changed? I can't quite understand what's involved in this part.
What do you mean changing over the LEDs?
All About Trance
Wow! The base '07 - '08 tails are setting your car off! Quick question for you. Can you tell me if your bumper sits flush with your tail lights or do you have a slight gap between them? I'm just asking because I just realized I have a slight gap between them a couple of weeks ago after inspecting my car closer than I did when I had first installed my Type-S tail lights over a year ago. LOL
Actually, I found that the fit was perfect on one side (right) and not as good on the other (left). The left light doesn't follow the bumper line 100%. If you look at the last photo the tail light on the left sticks out ever so slightly over the bumper line. It is probably only around 1/16" so not noticeable unless you are specifically looking for it. These were not OEM replacements but cheaper aftermarket lights from an eBay store. For the price, I am pretty satisfied!
All About Trance
I'll probably have to re-do it when it starts to really bother me. Other than that, I guess I can live with it.
To be honest who ever said that the Type S lights look bad on the WDP is insane!... ive seen many guys in this site where they have replace the lights and it looked amazing.. I myself am not a fan of the O7-08 base tail lights but rather get the Type S...just looks wayy too nice
Engineer
but really at night when they're on, they look pink.
i've followed a 07 WDP at night one time for more than 5 mins and i kept complaining why the LEDs look pink compare to the center brake light from inside the car.....
that's the exact reason i didn't go for them since then.
handsom-hustla
11-13-2015 05:04 PM
wusty23jd
09-24-2015 11:41 AM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
