Photoshop Request for 18'' tenzo wheels
Time for me to buy some new wheels. Theres 3 black rims i love made by tenzo. If anyone here could photoshop a pic of each rim on my car thatd be awesome! im just tryin to decide which wheel to buy out of the 3. heres some pics of the 3 rims:
Tenzo dc5
Tenzo Type M
Tenzo Project 7
Then heres a pic of my car:
Tenzo dc5
Tenzo Type M
Tenzo Project 7
Former Whyner
I would say DC5 to expose the Brembo more.
I like your murdered out theme but may I suggest remove the pin stripe and black or red lugs
Other than that looks great I want to do the same with my stocks. Did you get them powder coated or is that a DIY??
wheels
i sanded down the wheels then primered them then used 4 coats of gloss black paint then 3 coats of clear coat. the Tenzos specs are 18X8 45 offset
wheels
all 3 of these wheels will fit. they have either 45 offset or 37 offset. the 17's only come in 17x7.5'' and the 18's only come in 18x8''. there are 19's also that are 19x8.5 or 19x10
sweeeet
nice photoshops ^ narrowed down to 2 rims now. the type m and project 7. the project 7 rim kinda looks like a black version of ethans (transmission) rims. very hard choice. could you make the type m and project 7 rims bigger?
I don't know, but it has always seemed to me that Tenzo rims don't really "pop" out on TL's. Looks bland? Is it just me? Or does anyone else also know what I'm talking about?
...or maybe no one has had them aggressively slammed on before?
2008 NBP Navi
FYI
I asked a similar question in this forum, and was told that a 5mm spacer would be needed.
https://acurazine.com/forums/showpos...&postcount=580
Real Cars Have 3 Pedals
I only need to run a 1/4" spacer in the front, BUT since I've installed Extended wheel studs in the front...I run 3/4" spacers for the simple fact that i DIDN'T want open-end lug nuts, cuz they show the gold ext. wheel studs....I want to keep the BLACK lug nuts that came with the wheels...
thats the only reason in run 3/4" spacers....
Yea i kno it gives the Ride a wider stance from the front...I kinda like it that way...its FWD.
I've also thought about doing spacers for the REAR...but i'll need to upgrade to the EXT. wheel studs....
That brings up another thing...
If you run a spacer thats 1/4" or above...
I would recommend getting extended wheel studs...
CUZ with the 1/4" spacer, the lug nuts will ONLY tighten so much...its not enough thread left due to the spacer
How hard/cost is it to install extended wheel studs? Did you do it yourself?
Do you recommended any particular store/online to buy the spacers (i assume these are hubcentric spacers?)
thanks!
Very nice pics! I think you just sold me on those rims. I had my eye on the DC-5 (18")... but I think the ones you have are better. I'll be getting 18" though
thanks!
thanks!
I did the wheel studs myself...Its not too bad of an install, the hardest part is putting in the extended ones w/o damaging the threads cuz they are almost twice as long as the oem studs.
I got EXT. studs from velocityshop.com based in FL.
I recom. u get the open-end wheel studs also.
I got the spacers from a local shop....Its not hub centric either, just some cheap brand...but it gets the job done.
oyayjoe
09-12-2015 04:40 PM
asahrts
09-04-2015 05:55 PM
