Lower Grill LED Strips
Old 10-31-2009, 04:10 PM
  #41
t3hanarchist's Avatar
Originally Posted by LaCostaRacer
^ I just installed them today so I'll take some night shots later on. The lights are pretty bright so they will be very noticeable at night.
The install is not that hard and a noob can do it. It took me about 2 hours to complete the job and the hardest part was removing those grills. Use the butter knife from the front to make things a little easier. I'll post night shots when I can. You'll need some wire strippers, a 10mm socket, screw drivers (straight for popping out plastic fasteners), and the add-a-circuit that you can get from a car parts store. This mod was a lot easier than replacing the license plate lights with LEDs.
yeah your pics made it look pretty simple, i am mostly worried bout doing the wiring and tapping into the power
what are the 10mm socket and add-a-circuit?
and this mod shouldnt void a warranty right? since you are technically not really modifying anything, just adding
Old 10-31-2009, 05:15 PM
  #42
LaCostaRacer's Avatar
The add-a-circuit is used to tap into the fuse panel for power. I like this solution because it is completely reversable if I decide I don't like the lights- no tapped wires or the sort plus I can pick a fuse that keeps the LED lights on whenever the engine is on. I like this idea better than tapping into the parking light sockets like the OP did.
The 10mm socket is used hook your ground to the 10MM bolt near the battery that the OP showed in his pictures. It's a very simple modification and should not void any warranty.
Old 10-31-2009, 05:21 PM
  #43
alright lacosta, thanks, im gonna order some LEDs sometime soon, and im gonna probably need your assistance
one last question: for the LED strip, how should the wiring be, i got some test strips that are just a + and - wire on one end, is that different from the plug-n-playe?
Old 10-31-2009, 06:29 PM
  #44
Yes, this is the same. The Oznium lights have plugs but eventually you will get to two individual wires at the end. Oznium provides and adapter plug that terminates to the two wires so you'll be good to go. You have the following setup:
<passenger LED strip> + <3 foot ext.> + <driver LED strip> + <3 foot ext> + <2 wire adaptor> : negative wire goes to ground & positive wire goes to fuse box or parking light plug.
p.s. I just took some 4PM pics and the lights are bright. The neighbor could see them all the way down my culd-a-sac at 3PM. They will be bright come night time. I'll try to post pictures tomorrow
Old 10-31-2009, 07:13 PM
  #45
awesome im excited to see what those look like! also, i get now a little you put the + end to a addafuse to the fusebox right? but i dont understand what i means to "ground" a wire (noob , please explain!
also, i have a 07 type s w/ aspec body kit, the lower grills are not like yours, mine i can completely put my hand thru it, so my question is, culd i do it w/o taknig the grills off?
Old 10-31-2009, 08:31 PM
  #46
Here are some dusk shots before the tricker-treaters come:
The LEDs are bright enough that I can see a glow in my garage when I park the car with no other lights on.
Happy Halloween!
Old 10-31-2009, 10:19 PM
  #47
Sick!
Old 11-01-2009, 09:27 PM
  #48
bzyrice's Avatar
I want someone to do it just like the way mercedes does it.. on the top row of the grill and all the way across..
Old 11-01-2009, 09:38 PM
  #49
Rev High; Drive Happy
o4Komodo's Avatar
I want to see it Porsche style...
Old 02-17-2010, 01:37 PM
  #50
Carly Curran
Label Snob's Avatar
LaCostaRacer:
Looks good! Now I am undecided whether I want to do the full 22" piece or just do 12" like you. I am going to use a cool white, but I'm having trouble finding a strip that I can cut exact.
Old 02-17-2010, 02:06 PM
  #51
Not where I should be
ML²'s Avatar
I looked into this style, like the TechArt Porsche 997...not cheap at all. You're looking at over $1000 easy for those lights. I'm sure you can find some cheaper led's but you would compromise both style and function.
Old 02-20-2010, 09:06 AM
  #52
5th Gear
exequtor1987's Avatar
not a fan of the idea. but I really like it in your car. nice mods.
Old 02-27-2010, 12:54 AM
  #53
Dano04's Avatar
I like the Idea. Did mine in july of last year. Looks Hot at night. Nice job guys. . Here's mine. . . .
Old 02-27-2010, 01:01 AM
  #54
cleptosis's Avatar
nicemaking if it takes some kind of shape besides a straight line i also like the single in the middle with fogs
Old 02-27-2010, 09:07 AM
  #55
Kro
Kro's Avatar
definitely not my cup of tea. but i am over 30. and like nice things to stay nice.
Old 02-27-2010, 09:13 PM
  #56
6th Gear
roachcane77's Avatar
Nice job, (and pics) zsameer, but I think I like the Steven Bell "Audi" headlight look the best. I probably will never do it to my TL-S though.
Old 02-28-2010, 03:17 PM
  #57
Steven Bell's Avatar
Received 6,470 Likes on 5,162 Posts
Thanks Roach! If you can do it, it's really well worth it. It's a lot of work, but the rewards are awesome.
Hey be sure to join our Type S Social Group at:
https://acurazine.com/forums/groups/type-s-social-group-74/
Old 02-28-2010, 10:01 PM
  #58
draztic1011's Avatar
here are mine:
Old 03-05-2010, 01:56 AM
  #59
The Big Dog!'s Avatar
Leds
Can you add another set of "lights" on the front without the California Highway Patrol being concerned about it? I wonder.................
Old 03-19-2010, 07:44 AM
  #60
da2rumac's Avatar
LocostaRacer: I'm thinking about doing this myself and I like your idea much easier but few questions for you.
1. the positive wire on left LED and and positive wire on the right LED have to be joined together and then connected to the single wire that goes to the fuse box correct???
2. you mentioned that the postive cable can go into fuse box or parking plug. I can't remember at the top my head but you said that you taped it where when you car is running the lights are on. However, in the fuse box is there a place for the parking lights where I could tap into?
Old 03-19-2010, 12:29 PM
  #61
d-townhakuzo's Avatar
Lacosta's is a bit cleaner. I will consider doing either of these...
Old 04-29-2010, 02:54 AM
  #62
tltoledo's Avatar
Just did mine, what you think?
Hey guys,
I just finished my LED strips, what do you think?
I did the add a circuit method, plugged into the Right Low Beam Headlight.
I want the LEDs to come on when the side markers/parking lights come. However, I couldn't do that through the Fuse Box.
Does any one know if I can do it without tapping directly into the parking lights??
Any help would be appreciated.
Sorry about the pics, my camera phone, it doesnt do it justice.
Old 04-30-2010, 10:51 AM
  #63
tltoledo's Avatar
I thought I'd add a better pic.
Check out my thread. https://acurazine.com/forums/showthr...1#post11974662
Old 05-01-2010, 11:15 AM
  #64
zsameer's Avatar
I just redid mine.
Old 05-01-2010, 06:22 PM
  #65
Aldous's Avatar
I just installed the Oznium headlight strips on the lower grill- one 12" strip per side. I followed many of zsamer's instructions but wired my lights so they act like daylight running lights instead.
I wound up buying the following from Oznium:
2 x Linear Light 3 foot Extension Cable = $3.98
2 x Side Emitting "Headlight" LED Strip - Neutral White, 1 Foot = $29.98
Subtotal: $33.96
United States Postal Service (First-Class Mail): $4.20
CA Tax 9.25: $3.14
Total: $41.30
Some other tips:
*removing the black plastic lower grills was the hardest part of the job; however, you can use a butter knife and carefully disengage the 8 clips from the front- this works best on the outer clips that can't be reached from behind the bumper.
* The LED strips have some 3M double stick tape that seems to work very well. I attached the strips the the large middle rib and there is plenty of material for the strip to fasten too.
* You can wire these strips in sequence like a strand of xmas lights. You'll want to start at the Passenger side lower grill and work toward the driver's side. You can snip the extra wire end on the passenger led strip.
* These oznium lights are plug-n-play and easy to install. You'll want one extension cable between the LEDs light strips and then you can use the other to go from the driver strip up into the engine compartment. From there, you need about 2' of wire to tap into the underhood fuse box.
* Like zsamer, I glued the wires on the lower grill before snapping the grills into place. There are two bulkhead supports behind the bumper that you can wrap the extra wire around for a clean install behind the bumper.
I'll attach some photos that I took in middle of the day. The LEDs are brighter than they look in the photos. The sun is shining in the direction of the strips. The strips will be much brighter at night and other times of the day and look good with the black backdrop.
The parts:
Where I tapped in for power:
Final underhood install:
Front view lights off:
Front view closeup:
Front view lights on:
Front view lights on (closeup):
nice.... i will have mine deliverede to me on wednesday.. i cant wait for it.. is it hard to install?? ill also have mine on the very same spot as yours.. btw how many % tint do you have on yours?
Old 05-08-2010, 12:09 PM
  #66
Aldous's Avatar
im also wondering the same thing for this one... if i tap it into the fuse box... does it means that the parking light is out, that it is now transferred to the led??? or is it still be able to to turn on at the same time as the parking light??
Old 05-08-2010, 05:18 PM
  #67
KB1Spec's Avatar
here is the LED strips that I have and installed. Good thing about these strips is that it is VERY flexible and can be cut into shorter length
http://hobbyemporia.ecrater.com/cate...hp?cid=1064604
Old 05-08-2010, 06:41 PM
  #68
9th Gear
likemike716's Avatar
looks somewhat unnatural
Old 01-12-2011, 04:38 PM
  #69
aimtimes100's Avatar
i disagree with the vast majoirty of these people.i love those strips and would like to know where you got them jakepham. very nice look to it.i also like how zaseemer put it on the grill but i think ill go with the way lacoastaracer wired his.id love to know what fuse you tapped into.i usually go with useless shyt like the cigarette lighter fuse since power flows through even in acc mode and when the car is on.plus i really dont have a use for a cigarette lighter since the battery life on my phone is amazing
Old 04-22-2011, 02:03 PM
  #70
ashdec87's Avatar
Here's how I did mine. They are VERY bright, especially at night. I have a dimmer in the mail to tone it down after dark. Right now light are hooked up directly to the parking lights, but will eventually be hooked up to a 3 way switch so I can choose from off/on/dim.
Lights look like they protrude more in the picture than they do in person. They are aimed directly ahead, so inboard side is recessed more than the outboard side.
https://acurazine.com/forums/picture...ictureid=42157
https://acurazine.com/forums/picture...ictureid=42158
Old 04-22-2011, 07:33 PM
  #71
bforbrian's Avatar
This entire thread just makes me want to cry.
Old 04-22-2011, 09:03 PM
  #72
Stepien20's Avatar
Old 04-24-2011, 09:56 AM
  #73
Suprstar's Avatar
Guys, good job on the install but I'm feeling it. I think the LED strip only looks good on new Audi's, Mercedes' and Porsche's. Sorry.
Old 04-24-2011, 11:18 AM
  #74
Autotradgic's Avatar
Clean install... But not for me.. but if it makes you happy then thats all that matter.. Deff have seen worse installs on a TL
Old 04-24-2011, 05:27 PM
  #75
6th Gear
nizzo718's Avatar
all of these are giving me ideas of my own thanks! good work by the way
Old 04-25-2011, 10:40 AM
  #76
robertran88's Avatar
sorry buts that fugly as hell SMH!!
Old 04-25-2011, 10:52 AM
  #77
i guess its just a matter of opinion.i like it
Old 04-25-2011, 11:46 AM
  #78
ashdec87's Avatar
meh like its been said, its a matter of opinion. The camera doesnt do the lights justice. I wanted to do something different than just the regular fog lights to make the car stand out a little, and I wanted bright running lights as I used to run my headlights as DLR's.
When I get a chance I'm going to pull the bumper off and cut a slot into the air diverters behind the grill and push the light back about 1/2-1 inch or so. They stick out just a hair more than I'd like. I also got the dimmer, need to tone down the brightness at night and when its foggy out. The lights tend to illuminate everything, making it hard to see..
quanaman
01-09-2023 07:33 PM
Acura604
2G RDX Photograph Gallery
27
10-08-2020 09:24 PM
rhdune16
09-28-2015 11:31 AM
4drviper
09-23-2015 07:42 PM
scionxb3003
09-22-2015 05:28 PM
Quick Reply: Lower Grill LED Strips
