LED it and forget it. (Turn signals)
iWhine S/C 6MT TL
Wanted to start off by saying THANK YOU to rodney for helping me out over the phone.
Finally got the time to install these bad boys! I will take night shots later!
ENJOY!
ENJOY!
iWhine S/C 6MT TL
iWhine S/C 6MT TL
Night shots!
'13 Hyundai Sonata
Originally Posted by 04WDPSeDaN
Originally Posted by ua6spec
Are the bulb pure yellow or they are amber?
'13 Hyundai Sonata
Originally Posted by Kennedy
Those are the "Eagle Eye" towers... I may have a winner for my super headligth project.
iWhine S/C 6MT TL
Kennedy is right they are eagle eye towers. I think 24 each. You will need to buy resistor blocks to slow them down so they flash at a normal rate.
They are amber. I don't think they sell yellow..
12 TL Tech, 10 MDX Elite
iWhine S/C 6MT TL
iWhine S/C 6MT TL
Originally Posted by bforbrian
Looks great.... but no switchbacks?
iWhine S/C 6MT TL
Originally Posted by korrupted
Nice, I want toe get the DLR and Fogs the same color as the headlights.
Do you have any suggestions?
Anywhere from 300 or less to do what you want.
iWhine S/C 6MT TL
Originally Posted by VQPower37
is it an ez install???
about 10 min per side. You have to know what 2 wires out of the 3 to tap the load resistor on. I installed the leds through the plastic splash guards in the wheel wells and then I unplugged the connector for the led and moved it into the engine bay which in there I had plenty of space to tap and mount things. Easy nothing really hard about it.
iWhine S/C 6MT TL
cliffside
I am about to install my resistors but i am not sure which wire to tap into. which one is the brake/turn wire and running lights/tail light wire?
iWhine S/C 6MT TL
^ I just did my fronts I didn't do anything with my rears not sure what the color of the wiring in the rear is. Sorry try asking it in the general topic area of 3GTL
I want to install LEDs for my front turn signals but don't want to wire up load resistors. I heard there are load resistor relays that replace your current blinker relays. If so, do they make it for our TLs and where is it located? Does anyone have pics?
iWhine S/C 6MT TL
Originally Posted by jungsoo726
hey what bulbs did you use for the 3000k fog lights?
i have a '07 tl with the facotry foglights and i want them yellow light hid. what bulb?
I have honda accord 4 door fogs, I think the bulbs for that setup is h11. I do have a 3000k HID foglight kit not just regular bulbs.
iWhine S/C 6MT TL
iWhine S/C 6MT TL
Originally Posted by BrianC636
Would 1 6ohm per side (1 for front and rear) be enough if you had LED signals front and rear?
No you would need 1 per light. Thats the way they make it.
iWhine S/C 6MT TL
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
