Interesting pictues from spoon.....
http://spoon-mechanic.seesaa.net/article/142481805.html
looks like spoon has there hands on a 3G TL-S and a 4G TL. i wonder if the owners of the cars are one of our members???
2007 TL
1 Post
They installed "Subframe Rigid Collar". It sounds like by installing this washer kinda thing over the rubber bushing, the subframe bolt hole location and the chassis bolt hole aligns better, increase the rigidity of the body, and improve the steering preciseness and the stability of the car. They used the same parts for JDM Odyssey.
In Search Of Sunrise....
That 4G belongs to guy on acurazine JTL-Dancho... i know he used to have a 3G but has now upgraded to a 4G.
https://acurazine.com/forums/4g-tl-photograph-gallery-296/japan-2009-10-26-a-749768/
https://acurazine.com/forums/4g-tl-photograph-gallery-296/japan-2009-10-18-a-748847/
https://acurazine.com/forums/4g-tl-photograph-gallery-296/hello-japan-765665/
https://acurazine.com/forums/4g-tl-photograph-gallery-296/japan-762719/
2008 335i e92 6MT
what my translator got:
"ACURA TL TypeS to Rijittokara was attached.
ACURA TL TypeS is from Osaka customers visit us.
"Because of large sedan sports, you want to improve the modal of Suteafiru.
Sabufuremurijittokara also want to put my car somehow, "at the request of
Joint surface of the sub-frame, shape, and now to examine the bolt diameter.
Lift up immediately, and try to examine the sub-frame to the left 4 places
Are entered into the body through the Gomubusshu.
As always jack to support sub-frame, 30mm and put them down so I checked out
Odyssey currently available (RB3) to be common for 判Rimashita.
The joint surface coating of grease Rijittokara well, as the position of the middle sub-frame
Tighten the bolts to slip using the private bar, complete installation.
Mounting time is 2.5 hours.
Generation rate is more parts will be ¥ 21,000 ¥ 21,000 + labor.
Your friend's picture on the right is the current TL SH-AWD. Today, the suit ACURA could Woah! !
The next day the owner came in from the Inpure!
"OK, I can feel the effect is great now. Was more than I was expecting her.
Out of the store, 出来Mashita felt immediately.
Heavy car, but I was uncomfortable in the beginning to dull to cut the steering
After Rijittokara wear is often damper moves, the steering at high speed
Axel is now pulling the fluffy feel less safe.
Straight, pulling cars with confidence Axel're good!
Heavy vehicle cost-effective, it is Batsugun. "
Inpure Thank you understand and easy!
Dal is also improved in the Suteafiru the beginning, to allow the safe driving
Here we are!
Thank you visiting us from afar. And if I can come to Tokyo direction
Please visit us! !
Posted by Hara"
Here we are!
Please visit us! !
Posted by Hara"
Sarlacc
Console & Computer Gaming
09-30-2015 02:15 PM
