Food 4 UR iizz
tehLEGOman
Received 1,982 Likes
Area on my XM
why does this tl look like every other tl ive ever seen? nothing original to see here folks.............
in all seriousness, i like it, looks tough, JDM without any JDM parts only suggestion id make is rather then have the markers on the rear view mirrors yellow also, black em out.
tehLEGOman
As you're driving, air goes through your engine bay and as it rises, it will go through and up your engine bay, resulting in a lower engine temperature.
Lifting it will let the air out from the back of the hood.
That is the job for hood risers, they're placed on the hinges of the hood.
So their purpose is to let more heat out by lifting the hood.
MY KBP IS BTR THN URS...
Heat rises.
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/factory-im-spacer-17108-rdj-a00-727819/
Actually in his case it's because he took the MDX intake manifold spacer, and put it on his car. There is not enough room to shut the hood completely so he had to get the spacer's...
https://acurazine.com/forums/showthread.php?t=727819
94 DC4 RS LSV/Turbo
you are getting a bit carried away with the yellow film... the theme is time attack.... keep it that way
here is my advice to you, take it off the headlights, fogs and turns... and put on a pair of nokya 9005 hyper yellow as your daytimerunning lights... and throw on a 3000k h8 hid kit on ur lower fogs... that should do it
NOTHING CHANGES ON THIS RIDE!
thx for ur op. thou.
Sometimes ppl try to get u to MOD ur ride to their standards...
they should understand that its NOT their ride....& maybe the OWNER is COMFORTABLE with they way things are.
Stand For Something
Car looks good man, im actually starting to dig that front grille.
But, im gonna have to input my honest opinion here... 2 things that look like shit... the attempt at the "A" emblem debadge on the trunk just looks horrible with those 2 pins or whatever the hell they are covering the holes. Please put the emblem back on. Also, try to change the window visors to the OEM ones, the current ones look cheap.
I had to run a 1/4" spacer & upgrade to extended wheel studs to make it fit with the BREMBOs.....
SPECs:
19 x 8.5 w/ 45 offset
NOTE: there is a possibility that you can get a lower more aggressive offset if you upgrade to ext. wheel studs and spacers.......
wish i would've thought about that before i bought mines...
Thx for ur imput thou...
Received 6,470 Likes
Acu-rate-kudo's to you for the look of your Type S. I'm diggin' the grill and the red trim on the wheels/tires. Have you considered red lugs to compliment the red trim?
