Burtch07's CGP Build
Old 09-20-2016, 11:50 PM
  #121
Burtch07's Avatar
I have a set of 20MM and 15MM from the stock wheels. I just ordered 5MM (rear) and 3MM (front). Not that big but when I look at them I think anything 8MM or more will be too much. I want to get as close as I can without rolling the fenders. It's the real struggle....perfect stance!! I'm actually looking to find a beater/fixer up so I can garage the TL for the winter. Maybe then I can get to all the projects I have sitting in the garage��
Old 09-21-2016, 11:41 AM
  #122
Jeff
Oh Sickest TL's Avatar
I just rolled my fenders lol
Old 09-21-2016, 12:10 PM
  #123
rockstar143's Avatar
Received 19,991 Likes on 14,500 Posts
ahem...
I just HAD my fenders rolled.
you're already a puss, don't be a liar too!
Oh Sickest TL (09-21-2016)
Old 09-21-2016, 12:17 PM
  #124
Jeff
yea I def didnt do that myself LOL
But I wasn't trying to imply that I did it
Old 09-21-2016, 12:34 PM
  #125
shiet, even when your'e being honest you're lying!
Old 09-21-2016, 04:27 PM
  #126
Jeff
no need to be a cuck j lol
Old 09-21-2016, 04:35 PM
  #127
Burtch07's Avatar
I guess I'll just road trip it to Canda and have you roll my fenders Oh....the Bernie Sanders rate of course
Old 09-21-2016, 04:40 PM
  #128
Jeff
trust me, you dont want me anywhere near your fenders lol. But srsly, my car was a repaint and had rear quarter panel work done to it so thats why I was super nervous about it. one rear side didnt turn out great at all but it is what it is. OEM paint with no bodywork I wouldnt even think twice about it, you'd be fine!
Burtch07 (09-21-2016)
Old 09-21-2016, 04:49 PM
  #129
Burtch07's Avatar
Well I'd have to find a reputable guy or gal to do so here in the SLC area. I'm not using my high school heat gun and wooden baseball bat method on my TL haha
Old 09-22-2016, 10:04 AM
  #130
Burtch07's Avatar
Love the overcast days here in Utah
Old 09-22-2016, 10:09 AM
  #131
Looks great!
Old 09-22-2016, 07:30 PM
  #132
Steven Bell's Avatar
Received 6,470 Likes on 5,162 Posts
Cool picture.
Old 09-22-2016, 07:41 PM
  #133
one criticism, pick a line and make it either flat vertically or horizontally....that road line being slanted is killing my OCD.
Burtch07 (09-23-2016)
Old 09-23-2016, 08:23 AM
  #134
BreezyTL's Avatar
Received 1,019 Likes on 761 Posts
Don't center the object in the frame too!
Old 09-23-2016, 10:37 AM
  #135
Burtch07's Avatar
Good pointers!! I had to pull off the shoulder a bit so I wouldn't impede traffic. Thanks doods, put this info into the memory bank
Old 10-03-2016, 01:46 AM
  #136
Burtch07's Avatar
So I ran into a snag this weekend. My front passenger coilover top nut somehow loosened up and fell off. I went over a bump in my neighborhood and I heard a loud metal clank. I took the wheel off to to see if I could see any issues, nothing looked out of place. Well later I went out that night to do some errands and every bump it was a horrific metal on metal banging sound. The sound was so bad I was nearly in tears!! So here is what I ran into, pics attached. So I got everything back on but my problem is that I can't get he top bolt from the coilover to tighten down. In a regular strut you put the Allen wrench in the top and use the wrench to tighten it. However on the tein's the hole isn't big enough to fit any Allen wrench inside of it. I really would like to avoid taking off the entire assembly if I can. I might just hit with an impact gun real quick but I know that's frowned upon, any other suggestions?? Also remember that that bolt was covereup by the front sway bar
Old 10-03-2016, 08:43 AM
  #137
BreezyTL's Avatar
Where is your top hat?
Old 10-03-2016, 11:27 AM
  #138
Burtch07's Avatar
I took it off to inspect the entire assembly.
Old 10-03-2016, 01:00 PM
  #139
BreezyTL's Avatar
Thats brutal! Is there enough room to stack some jam nuts back to back above the nut you are tightening? This will give you something to hold on to until you can tighten the nut you need to. Then just break the 2 jam nuts free and remove. Hope that makes sense. This is what I do when I have to bust a nut doing worm shafts on a gear box.
Old 10-03-2016, 01:57 PM
  #140
Jeff
lol bust a nut
Old 10-04-2016, 09:14 AM
  #141
Burtch07's Avatar
I busted a nut last night but not on my TL hahaha, I have a walmart service center less than 1/2 mile from the house. I drove it with my blinkers on and they let me use their air drill to tighten it down. I was very cautious to not over tighten it. So far it seems to have worked so I'll just keep an eye on it and make sure nothing sounds out of place.
Old 10-04-2016, 09:21 AM
  #142
BreezyTL's Avatar
I was worried for a moment there, then I finished reading. You let a wal-martian touch your car, then was relieved to see you did it yourself!
Old 10-04-2016, 12:01 PM
  #143
Burtch07's Avatar
hahahaha yea I wouldn't let that happen in a million years!! But that nut bustin went down for sho doe
Oh Sickest TL (10-04-2016)
Old 10-04-2016, 03:07 PM
  #144
Jeff
Old 10-06-2016, 07:41 PM
  #145
Burtch07's Avatar
Good by cruel world of "Tighten Fuel Cap"!!!! Swapped out the old one from Mexico and put the one from Japan on. So far so good, maybe the best 55 bucks I've spent on the TL so far!! The write up on this problem was spot, the bolts were a little problematic but it only took me round 30 minutes.
Old 10-07-2016, 09:21 AM
  #146
BreezyTL's Avatar
I replaced mine a little over a month ago. No message since!
Burtch07 (10-07-2016)
Old 10-07-2016, 09:26 AM
  #147
Burtch07's Avatar
I'm soooo excited to never see that message again!! Now I have to figure out why my TPMS sensor system is failing, ever since I put on the new wheels on it's never went off and I put new TPMS sensors on the wheels
Old 10-07-2016, 09:37 AM
  #148
BreezyTL's Avatar
I am not to familiar with them even though I have them now. Maybe they need a re-flash?
Old 10-16-2016, 09:14 PM
  #149
Burtch07's Avatar
So I took my boys out on a foods only camping trip last weekend. I didn't want to take the TL but the wife was working late and I wanted to leave Friday night. I ended getting a few cool shots of the TL in some sweet landscape of Southeast Utah. Enjoy
Old 10-17-2016, 11:36 AM
  #150
BreezyTL's Avatar
Great shots! I love the second one.
Burtch07 (10-17-2016)
Old 10-17-2016, 02:41 PM
  #151
Burtch07's Avatar
Oh yeah that was a spot called Industry Butte, these doods were out there on their dirt bikes just tearing the sides of these butte's up. That's what those marks are from. It's pretty sad but I got a lot of pics but for some reason when I shot there must have been too much exposure because when I uploaded them at the house all the background was barely noticeable. Maybe because it was so bright and the ground was a very light dirt color and I had no lens filter or shade thing on they came out that way, I managed to salvage a few but lost quite a bit of them. I also noticed most of my shots are of the driver's side....guess I'm biased.
Old 10-17-2016, 08:23 PM
  #152
ryanfett's Avatar
Awesome shots! Man I would love to ride out there..
Old 10-17-2016, 08:26 PM
  #153
Use one of those shots as your first Avatar!
Old 10-17-2016, 09:46 PM
  #154
Burtch07's Avatar
Well said Steven, I never even really noticed I didn't have an avatar. Thanks kind sir
Ryan
ride out here and we'all go together, snap a ton of pics and do some off toading on the dirt bikes or 4 wheelers
Last edited by Steven Bell; 10-18-2016 at 07:44 PM. Reason: Merged Posts-please use the Multi-Quote button (the middle icon) in the lower right hand corner of each post to make it look like this.
Old 10-18-2016, 06:31 AM
  #155
ryanfett's Avatar
hell yeah, I'm down!
Old 10-18-2016, 09:46 AM
  #156
Burtch07's Avatar
I see a ton of typo's in my typing....makes me sick!! haha
Old 10-18-2016, 11:30 AM
  #157
ryanfett's Avatar
lol I don't judge
Burtch07 (10-18-2016)
Old 10-20-2016, 07:44 AM
  #158
Looks awesome, man...
loving the backdrop.
Did you ever properly address that coilover? The top is a small allen for dampening adjust, not for tightening down, right?
I believe there are 2 shaved areas on that top threading to allow the use of 2 spanner wrenches to tighten. If not, impact and a vise grip ever so slightly on the damper strut to keep it in place.
Old 10-20-2016, 08:59 AM
  #159
Burtch07's Avatar
Rocker
Yes I had to go with the latter and tightened it down via impact and very cautiously. It's been just fine ever since, now I have some weird clunking noise from the drivers side. Me thinks it's the end links are loose or something down underneath there. I'll look at it this weekend when I take the front fascia off to re-do my headlights. Backdrops around here so amazing, I'll get up into the mountains here soon and get some of the TL in the colorful leaves.
Old 10-20-2016, 09:02 AM
  #160
heck yes, awesome!
my oem endlink on the front actually pulled out from the inside joint...funny cause visibly it looked fine until you tugged on it.
Quick Reply: Burtch07's CGP Build
