18x7.5 A-Specs on 3G TL?
2014 Jeep SRT
7.5" wheels would cut through snow like a mofo.
Arthur, you gonna try and put 275 tires on a 7.5" rim?
Received 6,470 Likes
John is just planning ahead......
The issue with the TSX rims is that in addition to the 7.5 width, also have an offset of +55 I believe. If I'm correct, these will be extra sunken. with 25mm spacers all around, and for just snow plow duty, I'm sure they would be fine. Without any spacers tho, they would probably look mighty awkward.
I don't think half an inch will make a huge difference like "plowing through snow like a mofo" it still depends on what tire you are using.
Also I don't think the +55 will clear brembos
You need at minimum a 15mm spacer with these wheels and the RL calipers. That is the size I needed for the same wheels to clear the RL calipers but there's very little spacer between the caliper and the wheel spoke. I guess if machining of the caliper bracket isn't perfect, then get a 20mm spacer.
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
4drviper
09-23-2015 07:42 PM
