XLR8 Test Pipe Now Available!!!
Old Oct 1, 2009 | 07:50 PM
Excelerate's Avatar
Former Sponsor
We now have our own XLR8 Test Pipe available for the 3rd gen TL.
For sale here:
http://store.excelerateperformance.c.../i-285244.aspx
The XLR8 Test Pipe replaces the third cat with a straight through 2.5" test pipe. This helps free up exhaust flow, especially when installing a j-pipe. The pipe also includes tabs to reuse the OEM heat shield. Also includes hardware and gaskets.
XLR8 Performance Exhaust products are designed for function, form and style. Each exhaust part starts with T-304 stainless steel, known throughout the industry as the highest quality material practical for after-cat exhaust applications. All exhaust tubing is mandrel bent on sophisticated CNC machinery for a precise fit and uninterrupted exhaust flow. What’s more, the use of T-304 stainless steel flanges offers high strength and complete resistance to harsh elements. All hangers, resonators, and tips are T-304 stainless steel as well.
Old Oct 1, 2009 | 08:11 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
... continuing to further the aftermarket for these rides...
Old Oct 1, 2009 | 08:40 PM
ssmtl2nv's Avatar
2009 g37s 6mt
good job
Old Oct 2, 2009 | 08:28 AM
pawelTL6MT's Avatar
Adding the Test Pipe and J-pipe would alter the sound, yes? But no drone?
And by removing the 3rd cat, wouldn't that fail emissions?
Old Oct 2, 2009 | 09:56 AM
lusid's Avatar
FTW
Is this just merely a BOLT-ON mod?
Old Oct 2, 2009 | 10:44 AM
KN_TL's Avatar
yes
Old Oct 2, 2009 | 10:46 AM
KN_TL's Avatar
It might alter the tone since you are removing a restriction and I doubt it would add drone.
Emission test depends on how tight the regulations are. In my state, they don't use a tail pipe sniffer, just read the ecu.
Old Oct 2, 2009 | 11:39 AM
jerome736's Avatar
Cool! Any plans for a resonated race pipe?
Old Oct 2, 2009 | 12:59 PM
Bearcat94's Avatar
AZ Community Team
I don't have this pipe, so keep that in mind.
I did the mid-muffler delete and resonator replacment (Dynomax) on the stock 5AT TL-S exhaust. Slight drone at low RPM (~1500) in 4th or 5th gear.
Added the ATLP J-Pipe. Reduced/eliminated the drone. Added the ATLP test pipe. That added back some slight drone in that same low RPM, high gear range.
You should NOT have an emissions problem. You have 3 cats. 2 "pre-cats"; one on the front bank and one on the rear bank. Then the J-pipe collector and then the 3rd cat.
As long as your pre-cats are in place, you should be OK. The car may not be ULEV II, bin 5 (or whatever), but you should pass. Also there is NO O2 sensor in the third cat, so no concern about the test pipe throwing a CEL or anything of that nature.
Edit: BTW/FWIW, I have to pass an annual NC emissions inspection. Last inspection passed no problem. Not a "sniff"/tailpipe test.
Old Oct 2, 2009 | 03:35 PM
Excelerate's Avatar
Former Sponsor
The j-pipe doesn't alter the tone much. The test pipe might alter it a bit. We are not deleting the primary cats with the test pipe, just the third cat.
Yes.
Old Oct 2, 2009 | 06:57 PM
TheChamp531's Avatar
Chapter Leader (San Antonio)
Any chance of a combo package group buy? Test pipe and J pipe ?
Old Oct 2, 2009 | 09:56 PM
Timb227's Avatar
Fear and Loathing in my
^ +1
Old Oct 3, 2009 | 09:53 PM
thcmagik's Avatar
tl-s ?
Old Oct 3, 2009 | 10:05 PM
TL|GTX's Avatar
A Black TL
yes this is for the tl-s and TL
Old Oct 5, 2009 | 11:02 AM
Excelerate's Avatar
Former Sponsor
We are going to be raising the price on the test pipe shortly. The material we use is T304 stainless which is expensive. The introductory price of $125 is as low as we can go.
We might do a package for the j-pipe and test pipe when our stocking order of j-pipes arrives. It will be probably around $510 plus shipping.
Old Oct 5, 2009 | 11:15 AM
greco9885's Avatar
u will not fail emissions for taking out the 3rd cat. there are no o2 sensors by it. only on the front and rear primary cat.
josh, technically it should be a race pipe. since many people are use to test pipe's being resonated. and race pipes being straight through...you know how people get confused easy
this install is a 5-10 minute DIY if you dont mind working on your back. just spray some bolt penetrator on the bolts/nuts, then remove, swap part and gaskets, rebolt and ur done.
Old Oct 5, 2009 | 12:15 PM
powerflow's Avatar
Wiggy Wiggy Wiggy
Technically speaking, a test pipe has at least one sensor bung. At least that's my understanding.
Old Oct 5, 2009 | 03:22 PM
I forgot, and probably should search, but I'm in Endocrinology Class confused as hell. How much does the Test Pipe gain? I'm assuming very minimal, with a change of exhaust note. How much you think (in whp) that the J-Pipe and Test Pipe will gain? And how long will you think the combo will last (forever or a short time) because I won't be able to mod my car until January
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
