Wow, My Dyno Results!
I want to do a before and after dyno on my 04 TL 6mt. Ordered AEM CAI, UR pulley, and Thermal spacer. I took my car to a shop with a dynojet. I'm very pleased with the results.
My first pull: 226.36hp/206.61tq
My second: 225.39hp/205.46tq
My third: 330.89hp/210.57tq (after 5 min break)
Here is the dyno sheet on the last pull!
[IMG]dyno[/IMG]
[IMG]dyno[/IMG]
[IMG]dyno[/IMG]
[IMG]dyno[/IMG]
BTW, the guy at the shop was very impressed with my numbers for a stock car!
Originally Posted by 3rdGenA-spec
nice numbers. where can i get the pully and spacer from?
I got the pulley from Josh of Excelerate Performance: http://www.excelerateperformance.com/
Dyno was before the mods!
I got all the CAI, pulley, and spacers installed to day by a local shop! All I can say is another satisfied customer!
First of all while reving the car, it sound wonderful (growling)! I was afraid that the car was going to sound louder! Unless you WOT pass 3k, you won't notice anything aftermarket! And it revs easier now!
Second of all, my car has more low end power! I see why you would get better gas mileage. During normal driving, acceleration is effortless!
BTW, I also wrapped the CAI with a heat shield for insulation. I guess I wouldn't be able to tell until the weather warms up again.
I'm scheduled for another dyno run on Tuesday. I can't wait to see the numbers this time!
wdp skyhawk
I got the spacer from this site: http://www.outlawengineering.com/tech.html
Tuesday cannot come fast enough for me! I wanna see the after numbers! You will be using the same dyno correct?
stock diameter pulley, or underdriven?
I have the underdrive pulley. I didn't know the stock crank pulley was so heavy! Does anyone know the weight difference? The UR has got to be only a couple of pounds!
Oem crank pulley = between 7 - 1/2 or 8 pounds.
Used a bathroom scale with a readout to the nearest 1/2 pound.
The UR Pulley (underdriven) = 15 - 1/4 ounces.
Used a food scale with a readout to the nearest 1/8 ounce.
Got the after dyno results!
Well, just came back from the dyno shop today and again very pleased with the results! Here is what I got:
Mods: AEM CAI, UR pulley, Thermal spacers, and Thermotek intake heat shield.
Before mods results: Max power=230.89/Max torque=210.57
Run conditions: 52.37 deg. F, Humidity: 16%, SAE: 0.92
After mods results: Max power=241.46/Max torque=222.29
Run conditons: 62.53 deg. F, Humidity: 22%, SAE: 0.96
Gains: 10.57hp/11.72tq
I will have my dyno sheet posted when the shop e-mails it to me.
Question? Since I've lost around 11% of power from the engine to the wheels, does that mean my engine power is around 270 now?
[IMG]dyno[/IMG]
[IMG]dyno[/IMG]
im asuming this was at the wheels. so.. how much pwr would be at the crank? id think it would be more than the 258 that acura rated it as. cuase it used to be what... 270? then now the sae rating puts it down to 258.
That's pretty deflating! Agreed...I would have figured more HP/TQ gain than 10. What gives? Nitrous anyone!
I think your SAE needs to be matched up for a proper comparison. The thermotek heat shield I believe, is the insulation around the CAI tube.
CTS-V Import Slayer
Ahh....ok! That makes sense now. A bit overkill IMO...AEM CAI's are coated with a heat resistant coating I believe? But I guess more couldnt hurt?
Originally Posted by CleanCL
why was the SAE adjusted on the 2nd run w/ your mods? also temps/humidty were higher. because i would think you should see closer to double your gains. i would think at least 20whp/20lb-tq w/ cai, pulley, and spacers.
whats the thermotek intake heat shield?
Originally Posted by MichaelBenz
Internet seach brings thermotek as a furnace mfg or something?
http://store.summitracing.com/egnsea...5&autoview=sku
https://acurazine.com/forums/showthr...ght=insulation
Here's one, no affiliation: http://store.summitracing.com/sitema...700+115+400356
A link to the company that manufactures Thermo-Tec based products: http://www.thermotec.com/
The correct spelling is Thermo-Tec. Sorry guys! I got the idea to do the heat shield from this thread. I'm all about keep the engine as cool as possible. It will be more effective when summer comes back around.
Originally Posted by 2004 TL
I do not understand why your car measured so much lower than mine on the dyno. I had mine tested in two sessions and it was consistant within 3hp and 4 ft/lbs between all of the runs (6 in all). Mine was measured with the wheels on, fan blowing on an open hood, in 60 degree temps, 60% humidity, and a cool engine to start. I know that there are differences between machines, but 48 hp? I think that you numbers are low. What are your acceleration times and speeds? That will tell you just as much as a dyno, or at least give credibility to the numbers. If you were seeing 300 hp in a 3500 lb car, you should be able to get through the 1/4 mile in the low 13's. But if you thought you had 300 hp in a 3500 lb car, and could not break into the 13's, then your power numbers are wrong. Thoughts?
Originally Posted by dan.....k
Yours are the highest #'s I have seen for an N/A TL. It seems like your using a dynapack dyno. They seem to put out the highest numbers. If your not, then what kind of dyno are you using? With your mods you should be in the mid 260's on a dynojet.
Honestly I could not care less about this except that it makes for good conversation.
Thanks for your response. I do not know what it was called, and I can't find my printed reports to upload onto the thread at the moment. I believe that my hp/ft-lbs ratings are correct or I would not be able to achieve the time to speed measurments I consistantly see as noted in my signature. I have mentioned in other threads previously that about 2 tenths in my 0-60 and the 1/4 times can be attributed to my attenuation of the clutch and shifting style from the old racing days, but nevertheless, power to the groud creates time to speed. You can't have one without the other. So regardless if my numbers are right or wrong on a dyno, they are sufficient to produce the time to speed numbers which validate my claim. Remember, the measurements were not "coached" or rounded up. Rather, they were rounded down, and in fact they are the lowest numbers recorded on all 6 runs. If we are assuming that there is about a 15% loss in the driveline, the engine is probably producing about 340 hp at the crank.
Originally Posted by juruki
And with only those mods you are getting the same amount of torque as the guys that are blown? There MUST be something wrong with that dyno or you have a factory freak.
CTS-V Import Slayer
let alone an "average" lateral G??
whats this?? 340 crank HP not F/I, never happen.
"Average lateral G"
This was performed on a very tacky section of pavement with very sticky tires, turning left and right for two full circles. Tire pressures make a huge difference. The gas tank was near empty, and I was the only one in the car so there was no extra weight other than my body weight to affect the measurements on the G-timer.
With the Nexen tires I am seeing measurements of .88 or so.
I notice you have lateral G's listed....where did that figure come from? I got a dyno and I never got any kind of "lateral G" measurement whatsoever? Also have been to the drags....and same....no "lateral G" measurement?
See my response immediately above for your answer. I am not fabricating any confirmed measurement, rather just reporting data. I am to old to bs anyone.
