Who's here has done brake upgrade for your Base TL ??
Anyone here has done the brake conversion for your base TL with the Type S' big brake front brake? Can someone please tell me the approx. cost for the full upgrade? I am currently own a 2007 TL base, Navi. and WOULD LOVE to upgrade it to the TL Type S' front big brake! Any lights and wisdom ?
big brake conversion
I have a 2006 base model with nav just like yours and i did the big brake conversion and you basically gotta get the nuckle assembly and it just bolts on.you probably best off going to a junk yard and get it because if you try to piece it
together its gonna cost you a fortune
We concluded in the other thread that a factory Brembo "Type-S and 6mt" brakes would be more expensive than an aftermarket 13" kit.
Search and you will find people that did the conversion. I think it was around $2,000. You can get the Rotora 4 piston 13" kit for around $1,500. Better brakes and less money and you don't have to swap out the spindle. I got mine used off of a member here for $800.
Wilwood makes a 12.6" front kit for $800 which is larger than the TL-S 12.2" brakes.
$2,000 will get you Racing Brake's top of the line kit which is awesome. Or it will get you Rotora's 13" front and upgraded stock size slotted rears with upgraded pads.
i didnt know this existed...it doesnt list a BBK for the TL on their site? i assume you can use the NSX kit?
However, after repeated hard stops, the larger ones won't fade as easily. This is where the BBK shines.
Soul_Deamon
11-13-2018 04:44 PM
09-17-2015 09:01 PM
nuldabz
09-03-2015 05:49 PM
