Where should I start?
i just bought my 06 TL where should i start? i wanna make it faster but i dont know much about cars and i dont want general info i wan info specific for my Acura so i turned here
and recomendations would be appreciated
THANKS!!
THANKS!!
There is a "Sticky" right below the "New Thread" button.
Or click https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/performance-modifications-tl-owners-701772/
^ plus one
OP I would advise you to first figure out your goals, then search and research your materials. Acurazine has tons of inforamtion on this car that has been out for almost 10 years.
Also, there is a thread (google 3G TL for newbies); that is another great place to start.
Good luck
Good luck
Mods are pretty personal.
what are some things that you think the car needs improvement?
Do you need more power?
Do you want her to growl a sexy note when you press the skinny pedal?
How about handling?
Does she hug tight while taking a curve?
tires? a great summer tire can improve 0-60 times, braking times, cornering limits, etc.
and first and foremost; MAINTENANCE!
Does she need anything.
ALWAYS always keep her healthy!
How about handling?
Welcome and this is a frequent question.
I would start with :
Maintence ( anything required ) ?
Off the bat I would do a oil/filter change.
Amsoil 5w20 with oem filter.
And 6 ngk plugs.
Then :
Cold Air Intake : I prefer Aem.
Pcd's : If you dont mind swapping the stock pre cats when its emsssions time. Honestly once there done once and shields are off its a piece of cake. Its the initial install that is a major pita even though ive now done it at least 10 times !
Suspension: either h&r springs and some koni shocks or ground control/koni or full coilover.
I strongly suggest these 3 brands as ive had experience with every brand for the 3g tl.
Budget ? Bwr ! Hands down. Want some adj. Go tein super street, want a serious coilover and dont mind paying serious cash ? Kw varriant 1.
Then I would do a full cat back. Either : custom, or xlr8. Or theres others : greddy, comptech, atlp etc...
4th : J-pipe. And no an aftermarket j pipe is not the same across the board.
I suggest either : atlp v2 $399 or xlr8 v2 for $450. I do NOT recomend rv6 v3 j-pipes!
Once all that is done it is often all that the avg person would want.
If you want more power... :
P&P stock runners, intake manifold and bore tb. Or do the 3.7 im/tb swap.
2) type-s cams or bisimoto custom cams.
3) xlr8 v2 UR pulley
Want even more power ?
1) p&p the heads
2) comptech supercharger
3) j&r turbo kit or custom
4) nitrous
5) engine management
6) build the engine
Etc.
Its up to you really. But I would start with cai/pcd/cat-back/j-pipe/suspension and go from their....
Just my 0.02 :d
And 6 ngk plugs.
Then :
1) p&p the heads
4) nitrous
6) build the engine
Etc.
Just my 0.02 :d
Former Sponsor
Give us a call at 203-483-6100 or send us an email to sales@excelerateperformance.com and we will help you out.
rockyboy
Aug 4, 2024 10:35 AM
cak165
1G TSX Problems & Fixes
Sep 16, 2015 08:17 PM
