What will PCD's do to her?
Old Mar 12, 2014 | 05:52 PM
  #41
azeezp13's Avatar
shifting at 7k
Originally Posted by Rick_TL-S
Might be best then if you're looking for an M3. Those cars will eat through your pocketbook even faster when the mod bug hits.
forget mods, you`re going to need to set aside 2-3k yearly just for routine maintenance.
Old Mar 12, 2014 | 08:38 PM
  #42
Scottwax's Avatar
Mr. Detail
Originally Posted by 350
They come with spacers for the secondary O2's, it just moves the sensors out of the exhaust stream further so they don't sense as much exhaust. I think most people are okay on CELs but it's gonna depend on the car. I've seen people use spark plug defoulers on other cars, same concept.
Coming from a couple 5.5 gen Maximas (4AT and 6MT), it was typical to deal with P0420/0430 codes with the original precats. Sometimes a reflash would work, sometimes non-foulers worked, sometimes O2 sims did, and sometimes only swapping out the precats worked. Pretty mixed it seemed with non-foulers on headers, seems most ended up using O2 sims.
Just be a lot of work to find out my car is the one that gets a CEL but seems like the results are probably worth the risk.
Old Mar 12, 2014 | 09:37 PM
  #43
bauermd's Avatar
My CEL comes and goes with the PCD's installed. I noticed it comes on mostly at highway speeds when I am not on and off the gas. Almost always comes on with cruise set.
Old Mar 13, 2014 | 01:23 AM
  #44
Scottwax's Avatar
Mr. Detail
Can't have a CEL here, won't pass yearly emission testing. No rollers but they do check for codes.
Old Mar 13, 2014 | 02:12 AM
  #45
bauermd's Avatar
Valid argument. Although my CEL is RARELY on, and when it does come on is only on for a day or two then goes off for a couple of weeks. I still get the dreaded "Tighten fuel cap" alert on bumpy roads but no CEL associated with that so i'm good.
Old Mar 13, 2014 | 04:55 AM
  #46
NvrDwn's Avatar
I never got a cel after I put on the pcds. Are your doodles whatever they are called pointing up? I mean straight up and tight.
Old Mar 13, 2014 | 09:35 AM
  #47
bauermd's Avatar
mm I am not sure. +1 for the advice though! will check next time I under the car.
Old Mar 13, 2014 | 10:04 AM
  #48
350's Avatar
350
My first ricer
I'd be okay with a random CEL, if it have a scan tool/Torque app you can clear it and if it stays off for a bit it would be good enough to get it through inspection, but that might get old quick. They're on sale for another month I'm probably gonna bite soon enough.
Old Mar 13, 2014 | 11:36 AM
  #49
Scottwax's Avatar
Mr. Detail
If I pull the trigger, it will definitely be the ceramic coated version. Had a DC Sport ceramic coated header on my old '90 Accord, really cooled down the engine bay.
Old Mar 13, 2014 | 01:33 PM
  #50
ultimatum127's Avatar
I love me some VANOS adjustments
Old Mar 13, 2014 | 01:35 PM
  #51
350's Avatar
350
My first ricer
304 stainless is very good at heat retention, I won't bother. If it was 409 or mild then ceramic coating is a must.
Old Mar 13, 2014 | 01:37 PM
  #52
If im already running an intake manifold spacer which i have since a a sizeble drop in engine temperature do i need to get the ceramic coated pcd then?
Old Mar 13, 2014 | 01:43 PM
  #53
Rick_TL-S's Avatar
You'll pass fine; I did. It's when the weather temps. rapidly go up & down that causes the car to throw codes.
Otherwise, as long as there's no CEL, you're good.
Old Mar 13, 2014 | 01:49 PM
  #54
I think ceramic coating is negligible.
as 350 stated, the steel already has great heat retention.
your engine bay is going to be hot regardless of ceramic coating...(explosions via spark and fuel are going off inside your engine)
to reduce heat, vent it out.
Old Mar 13, 2014 | 03:31 PM
  #55
Scottwax's Avatar
Mr. Detail
I take it the inspection station didn't look too closely at the engine, eh? Don't even remember if they opened the hood on mine, just hooked up a code reader and tested the gas cap.
Old Mar 13, 2014 | 10:40 PM
  #56
nate_0022's Avatar
Land of 10,000 lakes
When installing the pcds can you remove the rear primary from the top? In a DIY I looked at in the garage showed the newer accord pulling the cat from the top. I receive my HFPC this Saturday.
Old Mar 14, 2014 | 01:13 AM
  #57
vietxquangstah's Avatar
I recall when I installed my PCDs I first removed the heat shield and was able to pull the rear cat through the top. I know there was a lot of tetris going on just to remove the damn thing.
Old Mar 14, 2014 | 01:40 PM
  #58
Elite1982's Avatar
i have the nonres atlp and rv6 v3 pipe, i hate the rasp...its embarrassing actually. I wanted to do the pcd but im second guessing..ill prob sell my setup and get the rv6 catback and call it a day.
Old Mar 14, 2014 | 02:49 PM
  #59
nate_0022's Avatar
I actually went the other route, I bought the ATLP V2 jpipe/race pipe and replaced my RV6 V3 jpipe. I'm much happier getting rid of that rasp and I actually like performace gains on top end. I should be installing my HFPC tomorrow hopefully.
Old Mar 14, 2014 | 10:53 PM
  #60
Rick_TL-S's Avatar
Unless they know exactly what they're looking for, I don't think most places are going to look. I think the code reader is all they rely on to tell them if there's cats or not.
Old Mar 15, 2014 | 12:23 PM
  #61
Scottwax's Avatar
Mr. Detail
I use the same place for inspections as I do for oil changes, they didn't say anything about my missing 3rd cat.
Old Mar 16, 2014 | 09:07 PM
  #62
I have v3 PCD's, v3 Jpipe, and ATLP resonated quads. The rasp was very annoying at first so I bought a bigger resonator to replace the one that was already on the exhaust. It reduced the rasp by 85% and is more subtle now.
Old Mar 17, 2014 | 02:03 PM
  #63
Elite1982's Avatar
so keep my setup at ATLP non res + ATLP V2 Jpipe significantly reduces rasp as opposed to ATLP non res + Rv6 v3 jpipe?
  #64
Elite1982's Avatar
If i keep my setup*
Old Mar 17, 2014 | 05:11 PM
  #65
Butter type-s's Avatar
Does anyone know if ATLP quad non-res with XLR8 V2 jpipe will create rasp? I search but all I could find was ATLP and RV6 jpipe.
BoricuaTL
Apr 8, 2016 01:08 PM
IIDXholic
Oct 8, 2015 07:53 AM
SiClone
Oct 1, 2015 10:22 PM
KBTypeS
25
Oct 1, 2015 04:49 PM
MonkeyTrucker
Sep 14, 2015 11:57 PM
