What all is needed?
Old Feb 12, 2009 | 05:58 PM
S2H80's Avatar
4th Gear
What all is needed?
First off, I unfortunately know next to nothing about the mechanics of a car. That being said, I was looking into getting a supercharger and exhaust for my 06 TL. Everything on it right now is stock. If i would get those 2 things put on, do i need to do other adjustments to the car, or will those things be just fine? I'm just looking to add a little more power to the car. Any advice is good advice at this point.
Old Feb 12, 2009 | 07:07 PM
paliknight's Avatar
those will add a lot more power to the car. and im not an expert, but i doubt you will need any other mods. i hope your TL is manual.
Old Feb 12, 2009 | 07:13 PM
S2H80's Avatar
4th Gear
Yeah it's manual. Just one of the posts kinda worried me because he was talking about a rod going through the engine because of to much boost. I don't know where to start with that kind of stuff.
audi_to_TL's Avatar
Search
RV6 precats, J-pipe, test pipe, light weight pulley, snow performance methanol/water injection
Once you add horsepower you will have to think about things like suspension, sway and strut bars, innovative mounts, brakes.
Old Feb 12, 2009 | 08:02 PM
Hi speed's Avatar
runnin a little boost
It seemed like that guy was beating the hell out of his car, so I wouldn't worry too much unless you are really hard on the car. As far as the Supercharger set up goes to get the full 100-110 hp you are looking at alot of money. My set up $4500 for the supercharger, $1000 for Pro-Cats, $400 for ATLP J-Pipe, $125 for the 3rd cat delete, $1150 for the Full ATLP catback, and $1000 geting the type-s rear bumper, buying all the extra parts having it painted and then installed. So $8175. Thats a big mod. You can do just the supercharger and some $1000 exhaust or get pre-cat deletes that remove all your cats, but you need to open up the rest of the exhaust to get the full effect. If you have the money is not a bad way to drop 8K, the car turns into a beast and makes daily driving 10x more tolerable.
You
Old Feb 14, 2009 | 11:30 AM
S2H80's Avatar
4th Gear
Well it's a good thing I just got back from a deployment not to long ago. It doesn't sound like a bad price for all of it. My next question is, is there a certain order this all has to be done in? Like can I do the ATLP J-pipe w/o getting the Pro-cats first? Can i get the supercharger before the exhaust?
Old Feb 14, 2009 | 01:04 PM
Trew's Avatar
You will benefit a whole lot more with that setup if you get a Cold Air Intake.
Also, if you do a s/c you will need a smaller battery or you will have to relocate it.
Old Feb 14, 2009 | 03:58 PM
csmeance's Avatar
before you dish out 5K for the charger, do the stuff so you can see the performance increase from being N/A (naturally aspirated where the engine sucks in air) than being F/I (Forced induction where the supercharger forces air into the engine)
Mods you should do:
AEM Cold Air intake - Allows for cooler air to enter the engine
Ported and Polished intake runners - bigger and smoother airways so the motor can suck in air easily.
Pre-Cat deletes - delete the catalysts to help exhaust flow
J-Pipe - remove restrictions in the stock pipe that restrict air-flow
Test Pipe - remove the third cat to remove restictions
Exhaust- make the car exhale easier
UR pulley (stock sized) - this will reduce the mass of the crank pulley so it can spin up easier and faster
I suggest that you get the AEM Cold Air Intake and the pulley, then the Precat deletes, J-pipe and Test Pipes. Then go with the exhaust. Lastly go with the ported and polished runners.
BTW what year TL do you have?
Old Feb 14, 2009 | 06:28 PM
S2H80's Avatar
4th Gear
Its an 06 TL, Manual transmission
Old Feb 14, 2009 | 07:59 PM
Hi speed's Avatar
I have the same car. I started off with just the supercharger and stock everthing else, It really makes you feel the differance as you add the pieces together. As far as the Pro-cats/pre-cats, you will not see the 100+hp gains until the exhaust is fully free flowing. You need to address the the cats to make the supercharger work best. My car was a super sleeper before my exhaust, it sounded like a f-1 car. It will really transform you car, the 6 speed is fun N/A, but add 100 hp and you are talking some serious fun.
oo7spy
Jun 19, 2023 12:48 AM
notfast
1/2G MDX (2001-2013)
Mar 28, 2023 08:10 AM
TLDude876
Dec 28, 2016 03:18 PM
2015TLX
Sep 11, 2015 02:56 PM
nuldabz
Sep 3, 2015 05:49 PM
