Vacuum lines on engine mounts?
Old Dec 28, 2010 | 06:14 PM
ITL's Avatar
ITL
I do my own work.
The front mount has a vacuum line running to the bottom of it. I've replaced my engine mounts with the XLR8 mounts, but have no idea what to do with the vacuum lines... I can't just leave them open, can I? Those of you that have replace your mounts, what have you done with the vacuum lines?
Old Dec 28, 2010 | 06:34 PM
libert69's Avatar
18psi
Do you ever plan on going back to OEM mounts?
If so, zip tie the ends of lines closed. You dont want any vacuum leaks.
If not, remove all the lines and remove the module on the rear of the intake manifold. Use a rubber cap on the nipple so you dont have any leaks.
If you dont want to pull the lines, then you can put that rubber cap over the nipple on the manifold to prevent leaks.
Old Dec 29, 2010 | 08:10 AM
Comptechtl2367's Avatar
You could also just take a screw and put it in the end of the lines if you dont want to take them all the way out. More secure the a zip tie IMO
Old Dec 29, 2010 | 08:20 AM
KN_TL's Avatar
I would plug the fitting as libert shows but also put something in the lines at the mount locations to keep the crap out just in case you do decide to use them again.
Old Dec 29, 2010 | 01:40 PM
I hate cars's Avatar
Cap or plug. I would cap also to avoid having a vacuum line just laying there.
Old Dec 29, 2010 | 02:52 PM
7.5AV6MT's Avatar
I put a screw in the end of mine with silicone grease...
Old Dec 29, 2010 | 05:58 PM
ITL's Avatar
ITL
I do my own work.
Thanks for the help.
I pulled the lines out and capped off the manifold. I noticed there's a small module to the left of where that vacuum line hooked up. The module is on the vacuum line between the manifold and the engine mounts. I noticed that in libert69's pic above, the module is not present and the harness is just sitting there. I suppose I'll do the same. Anybody know what the module is?
I was thinking maybe I could just put the module back and plug in the harness, but I have no idea what it is...
Old Dec 29, 2010 | 06:13 PM
KN_TL's Avatar
It's the control module for the mounts. If you aren't using stock mounts then it's useless.
Old Dec 29, 2010 | 06:31 PM
ITL's Avatar
ITL
I do my own work.
okay. I just wanted to make sure is wasn't going to bork anything ECU related. thx.
As well, just for purposes of documentation, the two top bolts for the side XLR8 mount were 1 1/4" too long, and would not tighten down. That's too much slack to take up with washers Excelerate hasn't heard of anyone having problems, so it may be something specific to my situation. (2004 6mt) I ran out to Auto Zone and got two M10-1.25 x 30mm flanged bolts. Maybe this will help someone searching for the same...
Old Dec 29, 2010 | 07:03 PM
That's interesting, I never know there was a control module. I just assumed more vacuum at idle meant a softer mount and when it loses the vacuum it goes firm.
Old Apr 28, 2012 | 02:47 PM
SAMCES's Avatar
Basicly that means that you can unhook the tubing from the mount to the solenoid and nothing happen?...
I'm thinking replacing my front and rear mount but I noticed the front tubing is missing..
maybe that cause some vibration during red signs with D4... when put in neutral the car feel smothh and runs great.
any advise?
Old Apr 28, 2012 | 03:02 PM
KN_TL's Avatar
Yeah, I used the port the controller was connected to for my added goodies. I did keep the controller connected but as you see, Libert69 and Inaccurate both removed theirs with no issues. You should probably at the very least put a plug on the vacuum port on the IM just in case the solenoid stays open unconnected or definitely if you remove it altogether.
Old Apr 28, 2012 | 09:48 PM
04socalTL's Avatar
spends his lunch $ on his
please forgive my ignorance but do you use a jack to raise the engine in order to install the mounts?
Old Apr 29, 2012 | 07:16 AM
KN_TL's Avatar
That's how I did it
Old Apr 29, 2012 | 07:35 AM
Nova_brad's Avatar
Just a heads up if you remove the control module... If you leave that electrical connector unplugged and decide sometime later down the road that you want to go back to stock, the connector will most likely have corrosion inside from the bare metal terminals contacting moisture in the air. It needs to have the weather pack type of seal to keep it out, that is the rubber seal inside one end of the connector that slides directly over an exact fit plastic piece on the module side, which keeps all the moisture out.
So I would either just leave the module plugged in with lines fully installed but PLUGGED, or if you really want to pull the module at least pack the connector full of dielectric grease and find some way of trying to cover the end of that connector.
Brad
Old Apr 29, 2012 | 08:27 AM
KN_TL's Avatar
That's what I did
Old Apr 29, 2012 | 09:00 AM
04socalTL's Avatar
another question, what part on the engine would be the best point to put the jack on?
last thing i would want is to push up on a weak point and damage something
Old Apr 29, 2012 | 09:54 AM
lilsid112's Avatar
^^ I believe the oil pan would be the best place. I would have a piece of wood between the jack and the oil pan to distribute pressure.
Old Apr 29, 2012 | 10:18 AM
Opel's Avatar
Right side of engine/ pass. Use the oil pan, but use a piece of 2x4 on the jack to distribute the weight on the pan a bit and you should be fine.
Old Apr 29, 2012 | 12:54 PM
ProbyOne's Avatar
You aren't the only one.
I ended up going a different route though. I used the top part of the factory side mount, the piece that has the grounding wire attached to it, in addition to the XLR8 bracket. I placed this piece on top of the XLR8 bracket but now need longer instead of shorter bolts.
IMO when buying mounts you should get all of the necessary parts. I'll pay 10 extra dollars for bolts if that is what it takes
Old Aug 3, 2018 | 03:02 PM
Mike shirley's Avatar
Question Vacuum motor mounts
Does anybody know if the Motor mounts get stiffer with vacuum or softer? At idle does the Silinold valve allow vacuum to motor mounts? Thanks
Old Aug 3, 2018 | 04:48 PM
EvilVirus's Avatar
OEM mounts should be softer with the vacuum lines attach.
Old Aug 3, 2018 | 08:20 PM
JMiles_T's Avatar
The vacuum line is for vibration dampening when the vehicle is in gear and stopped, like when you're at a red light. You'll notice they aren't on the cars with manual transmissions because anyone at a red light will be separating the engine from the drivetrain using the clutch pedal anyway.
Old Aug 4, 2018 | 08:39 AM
Motor mounts
so we install new motor mounts but the car vibrates alot now when car is at idle in gear. So we try and took off vaccumn hose from silenold valve and it does vibrate as much. We did buy the new mounts from Rockauto. I was wondering if the mounts that we buy are working opposite then the OEM's?
Old Nov 4, 2018 | 08:42 AM
JMiles_T's Avatar
If you want comfort, you need to buy the Honda/Acura mounts. I haven't found aftermarket mounts that won't make the whole car vibrate.
drone619
Jan 26, 2016 07:09 PM
BKSleeper
Oct 7, 2015 10:20 AM
Aging-Hacker
Oct 5, 2015 11:44 AM
sockr1
Oct 1, 2015 01:31 AM
Mr.Tea
Sep 14, 2015 09:58 PM
