Update from COMPTECH
I just spent a 1/2 hour talking to Nate at Comptech.
Just a few things:
1. As Lookinco has stated, a High Boost Pulley is available for 04-06 TL, I just ordered one. (It has not been tested, so it's use at your own risk.)
2. Comptech and Hondata are still working on a reflash. Like I have said before, Hondata is still in the process of making a wiring harness. I have been told maybe by the end of next month.
3. Comptech should have a Type S in their hands in the next week or two. He said they would be doing fitment and testing soon after that. So, you all with the Type S should have a few goodies pretty soon. But, as we seen before, Comptech like to take there time.
Just a few things:
Just a few things:
Just a few things:
thanks for the update bro. i'll call them today to order one!! i read somewhere on here that somebody already has one, but he's only boosting up to 8 pounds... do you know if they have one that can push 10?
I just cancelled my order for the pulley. After talking to Ryan in the tech dept, I want to see a dyno graph and see what lookinco says about his car running lean and possible detonation. He warned about possibly maxing out the injectors at high RPMs.
Originally Posted by blktl1
If you are running the boost cooler you will most likely be okay with this setup. I am also running the 3" pulley on my blower. you will have detonation if you just run the pulley and nothing else. if you run the boost cooler you can run the pulley with no problems.
Which boost cooler are you using? How much faster is your car with the pulley? Do you have any approximate gains?
I dont have any approximate gains but I can feel a difference. if i down shift into 2nd at like 4k, my tires will spin. I did not have that before. also I have the snow performance kit. using the 50/50 boost juice. My clutch is toast so i cant do any real hard shifts or it slips. I will hopefully be getting a new clutch this week! and will be dynoing the same time! I will keep you updated!
clutch and pressure plate - 22105-RDB-315
flywheel - 22100-RDB-L01
I think I am going this route soon, as my clutch is starting to go. The type S also has a new brake master cylinder that I am going to put in. Anyways, thanks for answering my questions.
Thanks. A few other questions. If you install the snow performance kit, can it be taken off with no tell tale signs of it being on there, i.e. if I trade my car in. Have you considered the Type S clutch and flywheel? They have new part #'s.
B A N N E D
I have 3" pulley with the snow performance kit. My motor is not running lean at all. It is actually still a tad richer then what I wanted.
The 07 TL seems to have a different fuel injector. I wonder if it's bigger for the bigger displacement.
what boost level do you have the boost cooler set on?? and also what does your boost gauge read. with the 3" I dont get and 8 PSI. I get about 6 tapering to 5
B A N N E D
I have hit at least 7.5psi and maybe a lilttle more. The boost cooler is now set to activate at 4.5psi. I am getting the variable controlller later this week to see if it works even better.
I am pretty amazed at how good the boost controller perform. I have the OBDII scanner so I could read all the sensors at real time. After about 45min of city driving, the IAT sensor was reading over 140F. I took it to a long straight and stepped on it a little. Once the boost cooler kicked in, the IAT sensor was reading 95F.
The boost cooler comes with a pressure switch. You simply turn the screw to adjust what PSI you want the boost cooler to come on.
Originally Posted by amm1232710
how would comptech no if u installed the upgraded pulley...cant u take it off and put the old one back back on if u blew the blower?
