type-s cam
Old Aug 25, 2008 | 10:27 AM
MANU2552's Avatar
type-s cam
did someone tried to put tl-s cams on a 04-06 base tl
Old Aug 25, 2008 | 04:24 PM
jdmspec333's Avatar
.43g at 900+fps
a couple of us did already. it fits, it works, but since none of us did the install without a before/after, we don't know the exact power increase. ussi, myself and a few others did it. do it, and get a before and after dyno and you'll be a hero. make sure you don't do any other bolt ons at the same time. thats why i can't give you an accurate result. i did all my mods at once.
Old Aug 25, 2008 | 07:24 PM
MANU2552's Avatar
i have my firts dyno result i am waiting for the camshafts b/o in canada.
Old Aug 25, 2008 | 08:15 PM
ABP_04TL's Avatar
6-SPEED LOVER
how much does this go for? parts only
Old Aug 26, 2008 | 01:30 PM
bent09's Avatar
horny =
Old Aug 26, 2008 | 04:27 PM
jdmspec333's Avatar
.43g at 900+fps
under 400 i believe. webcam has a grind for 04-06 base that goes for about 600 if i remember correctly.
Old Aug 27, 2008 | 02:05 PM
ILLustriousUA6's Avatar
Feenin on some 20's
not to be off topic or anything but does anyone know how big the TL-s injectors are compared to the base tl??
and where can you buy the tl-s cams at?
Old Aug 27, 2008 | 08:08 PM
jdmspec333's Avatar
.43g at 900+fps
dealership. thats where i got mine
Old Aug 27, 2008 | 08:19 PM
milk man's Avatar
do you have to change anything else when you change the cams? Like springs and retainers? or you can jst drop in the cams?
Old Aug 27, 2008 | 11:20 PM
jdmspec333's Avatar
.43g at 900+fps
for the type-s cams, i just dropped them in. if you're going with webcam or any other custom cam, then you should upgrade the springs
Old Aug 28, 2008 | 10:13 AM
Black_05_TL_6SP's Avatar
Ryan Christopher
I can not remember if you did the install yourself or had someone do it. How hard is it to swap the cams on the J32?
Old Aug 28, 2008 | 11:18 AM
ussi's Avatar
I (don't) whine.
you don't have to change anything but the cams. i would change the springs which comes out to like an extra $150 ($5x32). Its not really necessary because the typeS springs aren't much stiffer than the base ~ 2lbs more tense.
Old Aug 28, 2008 | 01:45 PM
jdmspec333's Avatar
.43g at 900+fps
if you can change a timing belt, you can change the cams. first remove the upper intake, then the timing belt covers. be sure to set the engine to tdc (top dead center). remove the timing belt. remove the valve covers. remove rocker assemblies. be sure to keep them in order so you can put them back where they came from. remove camshaft access cover on back of cylinder head. hint: it faces the driver side fender. slide cams out. reverse the procedure to reinstall. don't be shy with the assembly lube. bukkake all over the cams and the rockers. reinstall and change your oil. use a conventional oil - no additives - to break in, and change oil early twice in maybe 3000 miles. thats what i did.
Old Aug 28, 2008 | 02:46 PM
blkaspec's Avatar
Full of water...
i dont want to sound stupid, but what will this mod actually do?
Old Aug 28, 2008 | 05:42 PM
special-ed's Avatar
Iro Ridg .308
type-s camshafts are lighter, yet just as strong or probably stronger than the base camshafts.......thus camshaft rotation faster = increase in HP = faster engine.
Old Aug 29, 2008 | 08:41 AM
blkaspec's Avatar
Full of water...
thank you
Old Aug 29, 2008 | 08:55 AM
milk man's Avatar
thanks bro
Jul 16, 2017 07:33 AM
DerrickW
Nov 15, 2015 05:52 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
